e4od od blinks
Old Sep 11, 2008 | 01:44 PM
northern hawk's Avatar
northern hawk
e4od od blinks
swapped trannies last spring and rebuilt has worked like a top. Just recent when truck totalt stops the od starts to blink than when given a touch of fuel pedal stops the blinking . od does not blink when in motion and works through all gears up and down.
This am the od light starting blinking when in motion and when I reset by removing batt cables and gave over an hour run the blinking has stopped all but when the truck " fully" stops than blinks , shot of fuel , than gone again.
Suppose I need to buy a code reader but does this sound like a bad ground somewhere? also if a poster can point in direction of total procedure to test relay and gp it would be appreciated (thought there was a sticky topic on this but cannot find). thx for any help.......
94 7.3 non turbo e40d......
Old Sep 11, 2008 | 11:23 PM
PLC7.3's Avatar
PLC7.3
WallyMart has code readers......... if you must buy one.
Try this info........ Ford Check Engine light Codes
or........ Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
Old Sep 12, 2008 | 04:54 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
Mine does the same thing right now. My tach sensor is not picking up at lower rpms sometimes and will cause my OD light to flash, Once my tach starts working again, it will quit flashing. It shifts great and its been like that for 1 1/2 years for me. Its just comming to a stop or at idle it will flash.
If your tack is not responding in low rpm all the time or is bouncing around or not getting a good signal, a new tach sensor will more than likely fix it. The TCM requires a good Tach signal along with the TPS and Speed sensor. The tack sensor is right where you put the oil in on the top of the IP GEAR drive housing. Its big and you can't miss it. Kinda angled towards the drivers side.
Other than that, It would require getting the codes. Hope this helps
Old Sep 12, 2008 | 12:17 PM
northern hawk
Thanks for replies . My truck does not have a tach but our symptoms appear to be the same , strange . Should have mentioned tranny went into safe mode yesterday but did not after I pulled and reset the batt cables. Took it for a 1 hr run yesterday after pulling the batt cables off and another nice run this morning and tranny worked well with od functioning properly also( od light did blink when truck was /stopped/idling only again).
Thx again for help PLC7.3 . You helped pull some tranny #s for me to make sure I had the right replacement tranny last spring and will take your advice and pickup a code reader from wallys world .od light has yet to throw a code since yesterday am so I'm not sure what to think but will have it read when it does next time. cheers guys
Old Sep 12, 2008 | 04:11 PM
FORD MEGA CAB!!!
Even if your truck does not have a tach on the dash, it will still have a tach sensor on the engine. The E40D's TCM requires an input for it. Good luck.
Old Sep 12, 2008 | 06:09 PM
northern hawk
Guess you can tell i am not so fluent in diesel repair ect to say the least but I am continually learning about this 7.3 with a crash course in the e4od along the route . Will price out sensor and replace next week myself since you already pointed out where it is even located on the engine . good weekend ......
Old Sep 12, 2008 | 11:26 PM
ford trans tech's Avatar
ford trans tech
two things will cause your symptom , a tach sensor that ceases to output at idle speed or a bad fipl sensor that the voltage is out of range at idle
you need to retrieve codes first to know where to begin
Old Sep 12, 2008 | 11:28 PM
ford trans tech
hold the throttle at wide open before starting the test or you will get a false fipl code
if you get a 11-10-23 thats a fipl code and 11-10-14 is the tach sensor
Old Sep 12, 2008 | 11:39 PM
FORD MEGA CAB!!!
Trans tech, Do you have the part number for the tach sensor? I went out to go pick one up the o-rilies can't seem to find it. Thanks
Old Sep 14, 2008 | 11:45 PM
ford trans tech
i,ll have to check at work , its been too long since i replaced one to remember the number
F150vettehauler
2004 - 2008 F150
Jun 21, 2014 06:31 PM
allingeneral
Aug 17, 2013 03:50 PM
snaponprofile
49
Aug 4, 2011 12:21 PM
NascarNut
1978 - 1996 Big Bronco
Jul 9, 2004 11:00 AM
woodyropes
Jul 14, 2001 01:35 PM
