Real World MPG
Old Sep 8, 2008 | 11:03 PM
basfire's Avatar
basfire
Real World MPG
I live near Lake Tahoe and took a trip to Montana, then to Colorado and back home. My truck is a '91 F350 4X4, 5 sp, 3:55, Banks Sidewinder. I'm carrying a Palomino pop up over the cab camper filled with food, gear, propane, etc. Weighs about 1800 lbs. Plus my wife and I. I tried to keep the truck, with help of the cruise control, at no faster than 62 mph. I constantly averaged around 16 mpg. I also put a fuel conditioner in each tank full. Yes there were a couple of times in the mountains, climbing passes, while bucking a head wind when the mpg were not as good. But if I let the truck work in the proper gear with a casual foot it still did ok.
I have the same set up but add a 16' flatbed trailer carrying a trail ready Toyota FJ40, about 7,500 lbs. I'll average 11-12 mpg.
Old Sep 8, 2008 | 11:55 PM
CheaperJeeper's Avatar
CheaperJeeper
That second number sounds familiar. I have a 10 foot Western Wilderness that weighs 2300 empty. Loaded with gear, food, and a 30 gallon tank of water it weighs closer to 3k. My Jeep and tow dolly weigh right around 4500, throw in me, my wife, & 2 kids, and I figure we're rolling 7500-8000 pounds (over and above the nearly 7000 pounds of the truck's empty weight).
Rolling with that load I get 10-12 mpg, depending on the terrain...
I never get 16 with the camper alone though. More like 12-13+. I only get right around 15 running dead empty though...
Old Sep 9, 2008 | 09:47 AM
ghunt's Avatar
ghunt
I've been getting right about 15 mpg driving mine back and forth to work and running around town.
That seems bad, but then I think to myself...hey, if I was driving a V6 Ranger I'd probably be getting worse city mileage.
Old Sep 9, 2008 | 10:15 AM
tpolley's Avatar
tpolley
i have a 4 mile round trip to work. it's half city streets, half highway. i pull out of the appartment, jump on the highway for about a half mile and get off at the next exit and i'm at work. i don't even bother getting up to 65 on the highway. i do that 5 days a week. weekend job's a bit further. if i do nothing else (which is almost impossible) i can make an 18 gallon tank last 2 weeks and i get 12-14mpg. maybe hit 14 once in the last 8 months. it's very rare. the guy i bought it from said "it gets 18 all day in the city"... i'm thinking he was just trying to sell a truck. on the highway, if i keep it around 65 i've gotten as much as 23mpg.
'92 regular cab 7.3idi 4x4 with 4.10's and a 5 speed.
Old Sep 9, 2008 | 11:32 PM
ford trans tech's Avatar
ford trans tech
89 crew cab dually e4od and 4:10,s averages 12.5 empty and around 10 towing my 16 ft enclosed trailer , it weighs 2000 lb empty
Old Sep 9, 2008 | 11:42 PM
Dodge/Cummins's Avatar
Dodge/Cummins
Hey, by golly, I think these REALLY are REAL MPGs!
It's refreshing to see real numbers!
Everybody's truck gets 18-22 when they are for sale.
Old Sep 10, 2008 | 02:56 AM
David85's Avatar
David85
Mine can get that on the highway, but its NOT for sale!
Short trips around town and tromping on it all the time, 12 MPG is not impossible either. Warm up time on the road can really kill MPGs with diesels I've found. 12.6 was my worst so far with the current setup.
Old Sep 10, 2008 | 06:51 PM
seizure911's Avatar
seizure911
The worst I get is about 12-13 (towing or winter). Usually its around 14-16. Every once in awhile (rarely) I've gotten 19-21 on the highway (probably with wicked tail winds). Most of my driving is around town short trips or short highway trips in traffic. I've got my pump turned down until it just smokes on hills but has no loss in power. I went back to stock 235/85 -16 tires with a more mellow tread (toyo's) so I can run higher tire pressure without getting too much center wear. Oil changes, driveline/chassis lube every 3-5k. The gear vendors didn't seem to increase the mpg much, maybe 1-2 max, but did cut the rpms down quite a bit. On the highway on long trips I go as fast as I can without getting a ticket (74-84). Thinking about putting a turbo on it.
Old Sep 10, 2008 | 09:09 PM
knash0727's Avatar
knash0727
I get about 10 mpg city, but my injectors leak like crazy. I think I have 6 that leak. On the highway I get about 11-15. My biggest problem is that I can not keep my foot out of it. lol
Old Sep 11, 2008 | 12:46 AM
optikal illushun's Avatar
optikal illushun
i get roughly 16-16.5 with my truck. the PO said he consistanly got 15 with it bone stock and with the mods i have and 35" tires i get better then he did...and i drive it like i stole it, i swear the tach sees redline in the first three gears reguarly LOL
Old Sep 11, 2008 | 07:01 AM
Dodge/Cummins
I get 14-16 in mixed driving and I drive it fairly hard, it sounds to good with straight pipes.
I still only get 16-17 max on trips..
I'm not complaining it wieghs close to 4 tons as I drive it, it's aCrewCab and it's 4wd. That doesn't all add up to stellar fuel mileage. My gasser only gets 12 on it's best day and it's a 351.
Old Sep 12, 2008 | 12:22 AM
LCAM-01XA's Avatar
LCAM-01XA
Mine's a weird one:
a) pump fuel screw turned up 60 degrees from how I got it - no freight and cruising at 55 mph or less on a good day I can get 20 mpg. Towing an empty 30-foot car hauler at same speed I get about 15 mpg. City mileage is about 12 mpg, running cold for the most part on a 5-mile daily commute
b) pump turned down 30 degrees from how I got it - no freight and cruising at 55-60 mph on a good day I can get 22 mpg. However, towing the 30-footer sends me down to 12 mpg and it don't matter much if I'm driving it nice or I have it bouncing off the limiter, fuel economy sucks either way. City mileage was about 14-15 mpg in the summer on that 5-mile daily commute.
I now live at a different place, it's 5 miles to work now, so 10 total for the day, and with the pump turned down and weather getting cooler I get like 10-12 mpg. So I just turned my pump up again, I can live with slightly less freeway fuel economy if I make up for it in the city, which is where I drive most anyways. That, and having the truck pretty much gutless is pretty darn annoying, as to get decent acceleration I have to push the throttle more, which also moves the shift points up, and I like sifting at 1600 much more than winding up to 2200.
Old Sep 12, 2008 | 10:08 AM
ghunt's Avatar
ghunt
I need to get a new tach sender for mine so I can see what RPM's I'm running, my tach doesn't work at all. I've just been shifting by ear.
Old Sep 12, 2008 | 04:53 PM
japar's Avatar
japar
I have 2 94 turbos 1 a 4x4 auto 3.55 I get 18 highway and the other a CC dually 5-speed 4.10 I get 14 highway thats both around 60- 65 mph. Now I just replaced the waterpump on the dually and left the clutch fan off and just finished to tanks and got both 16 mpg. So I gained 2 mpg with no fan with no cooling problems. Wish I did it long ago
Old Sep 12, 2008 | 09:08 PM
a711112a's Avatar
a711112a
japar
do u do much city driving???
