Switch Placements
Old Sep 10, 2008 | 08:20 PM
  #31
superduty4x4's Avatar
superduty4x4
Here are the switches in my truck... currently not hooked up to anything. They will probably end up as EBPV and TC lock.
Old Sep 10, 2008 | 09:56 PM
  #32
bigsteve1969's Avatar
bigsteve1969
Originally Posted by King0581
Here's mine. Not a real good picture of the mounting though. I have them mounted in the fuse panel cover, in a piece of stainless steel that angles them out at the bottom so I can see them.
how much did that setup run? not bein too nosy or nothin but i would like 4 even if i dont use them all right now ha ha
Old Sep 10, 2008 | 10:11 PM
  #33
Ponyboychris's Avatar
Ponyboychris
OK, all kidding aside, that is sweeeeeeet. Need to get my hands on a set of those.
Old Sep 10, 2008 | 10:30 PM
  #34
sideshow's Avatar
sideshow
Originally Posted by totin_tools
Kevin, if your lights are on all the time you need to move the hot wire around to the other terminal. They should only iluminate when on. Should have 3 connections move them around a little and see if it doesnt change for you.
i'll try that. i thought they should only illuminate when on, but i'm no electrician. i mean i can install stereos and whatnot, but for some reason, switches and relays etc, were always trial and error, sometimes more error than not
Old Sep 11, 2008 | 08:41 AM
  #35
thbowen's Avatar
thbowen
Thanks for all the pictures and ideas. When I get around to getting them done I will share a picture with you.
Old Sep 11, 2008 | 09:43 AM
  #36
jgc2521's Avatar
jgc2521
I went for the hidden look. I dont have a pic but its not hard to explain.
If you take off the cover that your knees hit when you're driving, they have a horizontal metal bar with holes in it. I just installed mmy switch faced down. I know it's there and it isnt hard to find, but best of all it's totaly hidden
Old Sep 11, 2008 | 04:14 PM
  #37
King0581's Avatar
King0581
My park lights were on the picture. The little bar lights red when they are on. Shane has them in many different configurations. He is the cheapset you will find these Carling Rocker switches with the symbols on them. Anywhere else has minimum orders for them. Dont know what I would have done with 99 more of each of these switches! HA HA. I've had them for awhile. Think all in all I had $60 in them. Cant really remember though. I had to have them for the symbols. Behind the panel it looked like an explosion in a spagahetti factory until I elimenated some wires and got some twist apart plugs from work to make it so I could undo the plugs and pull the panel out.
Old Sep 11, 2008 | 04:16 PM
  #38
bigsteve1969
so how do i get in touch with him?
Old Sep 11, 2008 | 04:19 PM
  #39
King0581's Avatar
King0581
roan65@yahoo.com His name is Shane Linse.
Old Sep 11, 2008 | 04:50 PM
  #40
totin_tools's Avatar
totin_tools
They should only be illuminated when turned on. I think you may have the ground on the hot. on the switch I have it says ground, load, hot. When I turn it on it illuminates. Ground is on the top so top is the on position. Does what your using the switch for work or is it on or off all the time?
Old Sep 11, 2008 | 05:21 PM
  #41
cangim's Avatar
cangim
This is where I installed mine at:
FWIW, the upfitter switches will fit with a little motivation, but the harness will have to be modified to make it work.
Old Sep 11, 2008 | 05:34 PM
  #42
bigsteve1969
now thats nice too how do you get the wires to go thru and stuff?
Old Sep 11, 2008 | 05:43 PM
  #43
cangim's Avatar
cangim
I had to take apart the ash tray and just use skeleton structure of it. The killer part is that when I close the ash tray, all switches will be switched off. I made a harness to go to the back and of them. There is quite a bit of space back there. I am only using 3 of the 4 right now. If you are really interested I can go get some more picutres of the wire routes and stuff. Been a while since I have done anything with them.
Old Sep 11, 2008 | 06:00 PM
  #44
bigsteve1969
i'd like some more pics i really like that setup that way i can get some low profile switches and hide um from my ride alongs ha ha
Old Sep 12, 2008 | 05:36 PM
  #45
cangim's Avatar
cangim
I understand the ride alongs playing with stuff, part of the reason mine are where they are. I updated gallery: They are at the bottom.
https://www.ford-trucks.com/user_gal...&albumid=20245
TenStrings
Nov 17, 2013 06:59 PM
Vsanzbajo
Mar 12, 2013 11:05 AM
Jumbo131
6.7L Power Stroke Diesel
Dec 28, 2012 02:25 AM
BobbyDiesel71
2009 - 2014 F150
Oct 13, 2011 08:42 PM
lparisi
Dec 15, 2005 04:19 PM
