Sponsored by: Kumho
broken left rear shackle
Old Sep 8, 2008 | 09:15 PM
fej70's Avatar
fej70
The left rear shackle on my 1993 F 250 broke. Anyone have suggestions or tips on replaceing the shackle as well as the sleeve and bushing with out removing the entire spring?
I have the bolt out in the spring pearch, but having a hard time removeing the bushing and bolt in the spring itself. If I have to use a torch, where would be a good place to purchase a new bushing, sleeve and bolt?
Thanks
Jeff
Old Sep 8, 2008 | 09:23 PM
quaddriver's Avatar
quaddriver
well its a forgone conclusion you are NEVER gonna get the 'bottom' of the shackle and the bolt off the hanger....so, drill out the rivets and reaplce the hanger.
now use a bi metal blade in a sawzall, or a cutoff wheel, or a plasma cutter, or some suitable method of destruction and get the head off, then drill out the rubber in the spring eye and use a ball joint installer to push out the rest of the bolt for the top half, then get all new parts and well heck, its easy now.
ps - do the other side for grins. if one side went, the other side is considering it.
Old Sep 8, 2008 | 10:12 PM
fej70's Avatar
fej70
Thanks for the tip. I will give it a shot and let you know
Jeff
Gotta love the tools of destruction..........aint nothin better the fireworks from a tourch.
Old Sep 9, 2008 | 06:58 AM
Lazy K's Avatar
Lazy K
The problem is the bolt is seized in the inner steel tube in the rubber. Just use your torch to cut the shackle close round the bolt head. Then set fire to the rubber bush, keep it burning for about 10-15mins. You will then be able to easily push the bolt and rubber out. You should be able to get a new bush at rockauto.com including poly bushes which are much easier to install. Good luck with it.
Old Sep 9, 2008 | 02:32 PM
Lazy K's Avatar
Lazy K
Just another thought if you need a new shackle try stengelbros.com as well as rockauto.com.
Old Sep 9, 2008 | 08:17 PM
fej70's Avatar
fej70
I was surprise my ford dealer had a shackle on hand. $35 include bolts. Interesting thing was it had 3 bolts and 2 nuts.
I was able to get the lower bolt out with out heat, but a can and a half of penetrating oil. Napa had the bushing and pin but that will take a couple of days to get, not a stockable part.
Now the fun will be trying to get the spring lowered enough to reatach it to the perch.
I think if I use a heavy duty ratchet strap, some chain and the front end loader as an anchor i should be able to get it back in place without taking the spring completly off.
Thanks for all the info.
Glad I found this site, great information
Jeff
Old Oct 24, 2008 | 11:25 PM
fej70's Avatar
fej70
Well after the schedule calm down I fixed my spring.
I ended up putting new springs front and rear.
Both shackles on the rears.
I had checked the fronts, found the one spring eye split and ready to break.
Needles to say, all were replace. Truck rides 100 times better.
Now for the modifications to add in the air bags in the front. The break lines through the frame are in the way. I should be able to move the brackets. Hopefully I can get that done before the snow starts.
Thanks
Great site
Fej
Old Oct 25, 2008 | 07:26 AM
Lazy K's Avatar
Lazy K
Good man. Glad to hear you got it sorted.
BGF100
Aug 29, 2015 07:51 PM
FordFETruck
17
Jun 29, 2015 11:53 AM
OldWoodsDiesel
Oct 22, 2012 07:45 AM
jmm
17
Jun 5, 2012 04:29 PM
nvreloader
Sep 19, 2003 02:02 PM
