sloppy shifter
Old Sep 8, 2008 | 02:25 PM
ken1509395's Avatar
ken1509395
sloppy shifter
We have a 89 f150 4x4, 302 with 5 speed manual. It will go in every gear, but the shifter is really loose. I pulled the 3 screws off the top plate and the shifter comes right out. I'm not sure about the two pegs sticking out in the top of the tranny. BTW the tranny is the M5R2. Is there a link to an exploded view maybe?
Old Sep 8, 2008 | 10:32 PM
9.ford.5's Avatar
9.ford.5
ya mines the same not sure what transmission it is for sure (95 f150xl 300 I6) but also my 3rd and 4th gear positions dont line straight up and down the 4th gear is down and to the right a bit from 3rd
Old Sep 8, 2008 | 11:11 PM
brown 4x4's Avatar
brown 4x4
Under the boot there's a bolt (17 or 18mm wrench, I can't remember) that clamps the stick to the lower part of the shifter. If this worked loose or wasn't tightened enough if the shifter was ever off, it can create a lot of slop in the shifter.
Old Sep 9, 2008 | 07:10 PM
jerg_064's Avatar
jerg_064
I had a really loose shifter a while back on my M5OD. There was actually a teflon gasket type thing that sits on the ball at the bottom of the shifter. The old one broke and that's when the shifter got really sloppy. Replaced that and she was smooth again, but you have to separate the ball of the shifter from the stick that comes up into the cab to replace it. might check to see if that's still there.
Old Sep 9, 2008 | 07:21 PM
tjthegreat's Avatar
tjthegreat
could be the shifter fork
Old Sep 9, 2008 | 08:51 PM
F150xlt's Avatar
F150xlt
There's a two piece plastic bushing that surrounds the bottom of the shifter ball. The bottom bushing usually crumbles into small pieces. It's held in the shifter cover by two press fit pins. Item 68 in the diagram. There are two pins only one is shown in the diagram. The pins need to be tapped out before you can install a new bottom bushing.
The bushings are item 106 and 104 in the diagram.
Here's a picture of the two bushings which I believe are identical.
At one time Ford did sell the bushings. Don't know if they still do. They do come in the M05r2 rebuild kits that third party companies sell.
Old Sep 9, 2008 | 09:42 PM
BroncoRoadKill's Avatar
BroncoRoadKill
They don't sell the kits, but sell the parts, just rebuilt my 95.
Went to grande ford around the corner from my dads shop
Old Sep 10, 2008 | 06:17 AM
ken1509395's Avatar
ken1509395
that looks like my problem. I have the pins but no bushings. We just got the truck a week ago so my guess is that someone took those bushings out or whatever. I'll try to go Ford this week and I will let you know. thanks for the exploded view, that really helped.
Old Sep 10, 2008 | 10:51 AM
9.ford.5's Avatar
9.ford.5
sweet...while we are on the subject does anyone know what would cause my gear positions to go wacky like they are? its just 3rd and 4th gear they dont line up like they are supposed to
1st 3rd 5th
2nd 4th R
kinda somethin like that
bfbiker
Jun 25, 2009 02:03 PM
Jordan M
May 8, 2009 05:53 AM
Mercury Bluz
Jul 29, 2008 08:21 PM
keepnthepeace
Sep 29, 2007 10:14 AM
JoeBlow
Nov 2, 2003 11:51 PM
