92 f150
Old Jun 24, 2009 | 09:11 AM
bfbiker's Avatar
bfbiker
92 f150
on the 92 f150 4.9 m5od was bad in it (main bearing gone )
It came with a good tranny.Had to take the top of the shifter (where the shifter slides down on to it with a pinch bolt) off to get it in the truck>I think I left it in 5th gear ,how do I get it back to N because when I re installed the shifter it wont move and I cant put it in where it would be in 5th gear.Also I'm reading it needs to be in 1st gear not n so looking thur the hole in the floor how do I shift it to that so I can put the shifter back in.Yes it shifter thur the gears on the bench and turned the tail shaft in all gears
I need to get this done asap as I'm haveing surgh on my l knee again on the first and its the only one I can gat in and out of for a while(wifes lil 200sx aint going to cut it)
Thanks People
Phil <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Jun 25, 2009 | 02:03 PM
Redneck1465's Avatar
Redneck1465
You might want to move this post to either the transmission section or to the part for the new 87-96 forum.
mno3fan
Modular V8 (4.6L, 5.4L)
Mar 1, 2013 12:39 PM
sddesigns
New Jersey Chapter
Mar 15, 2010 02:29 PM
FORD E-150
Jul 10, 2009 03:21 PM
rebelpride1653
May 4, 2009 09:05 PM
Pappys53
Mar 17, 2009 08:04 PM
