4r100 tranny
If you had the same failure and only 83,000 miles you might consider replacement of the valve body. I had 148,000 miles and the fluid had been changed frequently with the Ford spec oil so I suspect you have a similar failure. I would have used Bryans but Gustov and Ike just would not allow me enough time to take that approach so I used a local person who specialized in the diesel Ford 100 tranny.
. For each person the definition of quality is what it means to that individual.
There are many ways to build a transmission, but if it is built and meets the quality definition of the customer then it was a quality job.
My dog is bigger than your dog serves no purpose in the definition of quality due to each person having their on definition of quality.
If the truck is only a show truck perhaps a stock tranny is quality for some, but if it is a heavy hauler perhaps a after market beef up tranny is more appropriate.
But you must also consider the design specifications of the equipment. If the equipment is designed to a specific job and is operated within those specifications then repairs could be satisfactory using factory stock parts.
So application, specifications, and individual definitions / expectations of performance determine if a good job was provided.
My transmission is being built by a shop local due to Gustov and their skills. I have met and discussed the rebuild on my transmission with the person who will do the work, before the work started. Expectations are clear. I know what parts, upgrades are being installed and made the choice on which upgrades I wanted installed. I am sure I could have the truck shipped to another state with a great transmission installed. But given MY specifications are met locally I will be satisfied if MY definitions of quality are met.
My definitions:
1) No leaks
2) Meets all shift points
3) No issues that require return
4) Transmission becomes a piece of the truck and forgotten because it just works.
5) It does have to perform as if it were a new truck transmission and meets the FACTORY specifications.
It does not have to have :
The most expensive torque converter
Upgrade Eprom for quick shifting on the drag strip.
There are many opinions on what a / how a transmission should be built but the final choice is up to the customer that pays the $$.
Ya'll have a great day. Texas watch out for IKE
comming your way.
