um wow.... Seems that some one didnt get what they were lookin for and got pissed.... Wow. Just wow, is this really what the world is coming to, people gettin there feelings hurt cause someone tells them its stupid and illegal to destroy other people property...
Wow.
Wow.
Right you are. Glad this is the exception instead of the rule here.
well, if you want to intentionally destroy the engine, just take the oil plug out of the oil pan. and drive it away till the engine seizes. .
or cut the lower radiator hose, wait till all the coolant is drained out, and drive it away till it heat seizes.
this will cause way more damage than over revving the engine, and you will get the satisfaction to know that you alone were responsible for destroying the engine.
and then do it to the next truck they give you, and continue doing it till there are no more trucks left running.
then you will not have to worry about driving the trucks anymore.
I'm not very familiar with this engine particular drivetrain, but I wonder if it would shut down before damage occured? I'll bet it would with no coolant at least. It appears to be pretty smart. Smarter than the original poster anyway as it has foiled him so far.
Put quartz dust in the oil, the motor will be trashed in under 1000 miles
A quart of bleach will wash out the bearings fast, but would be hard to explain
Mike
you are 100% correct Mike.
it is a computer controlled engine.
when the computer senses no oil pressure or high coolant temp, it will automatically cut off fuel flow.
and Andy, you should know by now that i never give out useful info.
