transfer case
Old Dec 12, 2004 | 06:03 PM
DT 466Man's Avatar
DT 466Man
transfer case
My truck has an NP208 and it works but it its shift pattern is seat-2hi-4hi-N-dash. It has been that way since i bought it N is very hard to get into i have to puch it all the way to the floor. Is it cheaper to take it apart and fix it or should i just find another one and put it in there?
What would cause it to have the reversed back a!! shift pattern?
I am leaning towards the shift forks but i'm not sure.
If i put another one in it would a BW1356 or a NP205 bolt in?
Could i Run twin sticks on any of these cases?
Thanks
DT
Old Dec 12, 2004 | 08:29 PM
DT 466Man's Avatar
DT 466Man
aNy one know?
Old Dec 12, 2004 | 08:42 PM
mustange70's Avatar
mustange70
If it were me i would swap a 205 in as its fairly easy to do, but really the only way to tell for sure is to pull the case and see what's the matter in there, but if you are to replace it i would swap a 205 in there. (i have a pic i can post that shows the 2 things i had to do)
Old Dec 12, 2004 | 08:59 PM
DT 466Man's Avatar
DT 466Man
is a 205 a part time? Will it bolt to my NP435? Will i need an adapter?
And the most important question: CAN I TWIN STICK IT?
Old Dec 13, 2004 | 01:39 AM
MontanaFord's Avatar
MontanaFord
DT...your shift sequence on your transfer case seems odd to me...i also have an NP208, but the sequence is as follows (dash to seat): 2hi-4hi-N-4lo where's your four low??? curious...
MontanaFord
Old Dec 13, 2004 | 01:03 PM
lmadore's Avatar
lmadore
I agree with MontanaFord. Where is your 4LO.
4LO can be a bit difficult to get in and out of. You have to be sitting perfectly still with the clutch engaged. Also easier if the truck is setting on level ground to keep the tension off of the driveshaft.
You cannot shift into or out of 4LO on any manual transfer case that I know of.
Old Dec 13, 2004 | 02:10 PM
mako5972's Avatar
mako5972
The transmission forum has a tech article on twin sticks, it is written by Ivan Ribic and is very good. I believe he used a NP205 and a NP208 if I am not mistaken.
Old Dec 13, 2004 | 02:57 PM
DT 466Man's Avatar
DT 466Man
yup 2 hi is at the seat
when you shift into 4 lo do you have to move the shifter left or right? Or just up and down?
What do you mean byQuote) You cannot shift into or out of 4LO on any manual transfer case that I know of.
Old Dec 13, 2004 | 03:14 PM
bremen242's Avatar
bremen242
sounds like the linkage was put on backwards. 2hi should be on the floor, and 4LO at the seat.
2HI-4HI-N-4LO
Old Dec 13, 2004 | 03:31 PM
DT 466Man's Avatar
DT 466Man
The linkage on the outside or on the inside of the case?
Old Dec 13, 2004 | 04:49 PM
bremen242's Avatar
bremen242
outside of the case.
Old Dec 13, 2004 | 05:47 PM
DT 466Man's Avatar
DT 466Man
well i looked under there today and it is just a rod thathas a pivot point and then an arm that connects the bottom of the shifter to the reansfer case
there is no pivot or any thing it looks like a teeter totter where the one end is in the cab and the other end is hooked up to a rob that goes to the transfer case.
Is it supposed to move left or right or up and down?
And if it matters the lever on the transfer case points down
Old Dec 13, 2004 | 10:05 PM
mustange70's Avatar
mustange70
The rod should move towards the front of the truck and towards the back of the truck. You should get someone to shift the t-case through all the gears while you watch to see what is going with the linkage, this should then give you an idea of whats going on.
Old Dec 14, 2004 | 06:37 AM
bremen242's Avatar
bremen242
I think that is the problem.. the lever should point up when in 2HI and towards the seat when you're in 4LO. Someone put the lever on backwards.
Old Dec 14, 2004 | 02:52 PM
DT 466Man's Avatar
DT 466Man
so the lever on the transfer case that has the rod connected to it shoud point up?
So some one fliped it 180 to where it points down right
thats just a bolt and a cotter pin right?
