Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1994 466 dt knocking?
Old Apr 11, 2013 | 02:14 PM
parkland's Avatar
parkland
As some of you know, I want to eventually do a f350/ dt466 truck for a project. So, I always have my eyes out for medium duty stuff.
I found a 1994 international cab chassis truck, with a 466, for 2000$
It has an engine knock, and it is 1994, so I thought it was HEUI, so I assumed one of the injector o-rings was finished, but after seeing pictures, it is in fact mechanical, you can see the injector pump and all the lines.
Does that automatically mean the bottom end is finished?
If I could buy this thing, I'd have a TON of parts that would be useful for building a truck project.
A 466 non running core is at least 500$, and thats a complete crap shoot, plus shipping or gas to go get it.
A running core is about 1000$ - 1500$ plus shipping.
This seems like a great way to get a ton of parts.
Has anyone ever done a project like this?
Good idea? Or am I just going to buy a pile of garbage on wheels?
1994 International 4900, S.A., air brakes, cab & chassis - Regina Farming Equipment For Sale - Kijiji Regina Canada.
Old Apr 11, 2013 | 07:17 PM
parkland's Avatar
parkland
I thought I'd just add that it sounds like knocking from the top, not the bottom.
Old Apr 12, 2013 | 09:31 AM
3414's Avatar
3414
You might want to get a mechanics stethoscope and use it to pin down the knock. Up top it could be wrist pins, or something as simple as injection timing off. I you know a mechanic who has spent time with diesels, see if he could listen to it and give you an opinion.
On if you should get it, you will have to decide to the parts that you will get from it versus the effort and time to pull them is equal in value to or greater than the $2000 price. A place to do this at and enough time to do it also will figure in. Good Luck!
Old Apr 12, 2013 | 10:51 PM
nevrenufhp's Avatar
nevrenufhp
Can also be an injector blew off the tip and has the chunks smashing into the piston.
The 466E started in mid 95, but you could opt for mechanical up to 97.
Just looked at the ad. Its a late 93 DT360...not a 466
Old Apr 12, 2013 | 11:53 PM
parkland's Avatar
parkland
Wow, how did you know that just from the pics? haha.
Old Apr 13, 2013 | 12:23 AM
nevrenufhp's Avatar
nevrenufhp
Now, this is what I picked out of that one engine pic. There are more differences.
1. The 360 ended in late 93.
2. Valve cover is almost a foot below the cowl. A 466 is about 4 to 5 inches.
3. Intake inlet points down. A 466C intake point straight up and has a 3" inlet.
Old Apr 13, 2013 | 10:12 AM
parkland's Avatar
parkland
Aha, I did notice the air intake, I just was hoping it was a lucky fluke of some type, lol.
Do you think an entire vehicle is a good purchase for this kind of project?
I think it is, it would make sense to me anyways.
If a semi-running 466 (needing a rebuild) is about 1000$, trans are usually about 500$, how much extra is it worth to have the entire vehicle , you figure?
I'm working on my go-kart project to get the garage ready for the next project.
Picked up toyota drivetrain yesterday, gotta get the axles cut down to fit the 48" wide body.
Old Apr 13, 2013 | 10:39 AM
nevrenufhp's Avatar
nevrenufhp
I've seen cab n chassis IH trucks go for $3500...with a running, p-pumped 466. Pass on this unless you can pinpoint the knock and prove it can be a cheap fix.
Old Apr 22, 2013 | 12:07 AM
rummur s.c.'s Avatar
rummur s.c.
Yeah buying this would be a mistake most likely. The same money can buy a truck with a good engine..
Although dt360's are somewhat hard to find..
Old Apr 22, 2013 | 12:08 AM
rummur s.c.
Theres a good 466 in an international cabover dump here in seattle for less than 2 grand.. if youre near by.
Old Apr 22, 2013 | 09:06 AM
parkland's Avatar
parkland
Thanks, but no, i'm far from there.
Manitoba, canada, which is north of north dakota.
Nicklatech
Apr 1, 2019 10:25 AM
dishman5000
13
Feb 4, 2011 02:58 PM
Montanagrizzly
Jan 10, 2011 10:01 AM
4inchlovin
92
Mar 18, 2008 08:27 AM
hink10
Apr 24, 2006 05:16 PM
