DT466e
Old Jan 2, 2013 | 12:10 PM
cowmilker08's Avatar
cowmilker08
Question DT466e
Our church bus is a late 90s with the DT466e. We have been having trouble with it dying after you start it.
Does anyone know if this engine would have glow plugs? I looked all over the engine and could not find any glow plugs, GPR or any wiring leading under the valve covers.
Isn't the DT466e an HEUI engine?
Old Jan 2, 2013 | 03:42 PM
79_250RangerLariat's Avatar
79_250RangerLariat
IIRC the 466 from the 1990's are traditional direct injection with a side mounted injection pump (might be thinking of the old I6 360). Easy way to tell is are their 6 lines running to a pump? hahaha
I never ran a 466 in my busses but the ones I ran (subbed for others) had a intake grid heater.
How long does it run before shutting down? Last filter change? Does it have the "rock catcher" before the main fuel filter? Looks like a 1" wide x 3" long cylinder that unscrews, has a cleanable filter inside.
Old Jan 2, 2013 | 05:12 PM
madpogue's Avatar
madpogue
According to this wikipedia page: Navistar DT engine - Wikipedia, the free encyclopedia - the "E" means that it's a HEUI engine, used starting in 1994. Alas, no info on whether it's glow-plugged or intake-heated. All the external links from the entry are dead.
Edit - some hint that it's grid heated, not glow-plugged - http://www.indeed.com/forum/job/dies...dt466e/t433413
Old Jan 2, 2013 | 06:36 PM
tjc transport's Avatar
tjc transport
i ain't rite
i have never seen a DT466E with glow plugs.
427 fordman's Avatar
427 fordman
That's got a cam sensor just like ours iirc. That is if its a late 90s. Look about in the same place as ours are. I'd try that if I'm correct
Old Jan 3, 2013 | 11:44 AM
cowmilker08
I don't drive the bus, but I'm told that it starts fine and runs really good for like a minute, then dies like you turn the key off. The it cranks for a while before restarting. When it does restart you have to play with the throttle to keep it going for about 10 minutes. The day I stopped to look at it, it started and ran like a champ with no hickups.
The oil, oil filter and fuel filters were changed in mid May when we purchased the bus. I saw the CPS and what appeared to be the HPOP with an IPR. The lines attached to the 'HPOP' went to a nearby filter. I assumed it was the oil filter, but the driver told me he got fuel from the filter when he was messing with it. (I didn't check myself, probably should have.) I couldn't find the injectors, so I assumed they are beneath the valve covers, but I couldn't find any wiring that goes in them either. The computer is mounted to the engine so its possible that the wiring goes out the bottom of the computer directly into the valve cover, I guess.
I figured if it kept acting up, we would replace the CPS.
Old Jan 3, 2013 | 11:55 AM
kellens's Avatar
kellens
Yes HEUI engine with injectors nearly identical to ours. Can't remember if they have glowplugs though.
Old Jan 3, 2013 | 12:07 PM
84-250's Avatar
84-250
No glowplugs. If it has a wait to start light on the dash then it has a intake grid heater. Being that old it prob doesn't have anything
Old Jan 3, 2013 | 01:48 PM
Talyn's Avatar
Talyn
yeah, IIRC its an intake heater on the 466. the rest of the stuff should be identical to our motors. just inline 6.
Old Jan 3, 2013 | 01:51 PM
Talyn's Avatar
Talyn
monster injectors though.
Bcodes.
Old Jan 3, 2013 | 04:09 PM
cowmilker08
Ok. Thats what I thought. There is no wait to start light, I don't think it has a grid heater either. I didn't notice any thing extraordinary on the intake.
What do you think about it dying like that?
Also, does anyone know where the pass-thru harness should be?
Old Jan 3, 2013 | 04:56 PM
madpogue's Avatar
madpogue
Gotta ask, given its commissioned usage, is it running on fresh winterized diesel? And/or, have they added any anti-gel elixir?
How many miles on the ticker since the oil change in May?
Old Jan 9, 2013 | 11:32 AM
cowmilker08
They have been adding anti-gel to the fuel. Around 6000 miles since the last oil change.
Old Jan 9, 2013 | 11:39 AM
madpogue's Avatar
madpogue
Unless that's synthetic, 6000 miles is pretty high miles for oil that does hydraulic duty as well as lubrication. Could just be breaking down to the point that it's doing a poor job maintaining injection pressure. At that many miles, an oil change wouldn't hurt anyway.
Old Jan 9, 2013 | 06:39 PM
tjc transport
i ain't rite
not really. most companies do a 10,000 mile oil change schedule with the larger trucks.
89ford460wrecker
Oct 17, 2017 08:42 PM
Tom Hairhoger
May 2, 2010 07:01 PM
84f250460
Dec 2, 2007 09:52 PM
cfrancis
Sep 29, 2007 05:37 AM
baddarryl
Mar 9, 2005 02:46 PM
