Need help finding a part.
Old Sep 6, 2008 | 08:39 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Hello all,
I was under the truck yesterday and noticed that the over load spring support thing since I don't know what it is so I am posting a pic of whats left of them.
Here's where it should go
I have been looking all over the net and can't find them.
So what I am looking for is a part number for the front 2 and the back 2.
Thanks again
Nick
Old Sep 6, 2008 | 09:16 PM
FordxFour's Avatar
FordxFour
Is this for the 01'?
Old Sep 6, 2008 | 10:05 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
I can tell you that the two front ones are mounted on top of the frame between the springs and the axle, they are call bump stops. I just replaced them on my EX. My local dealer found them (Part number YC3Z3020AA) they listed for 36.10 at the dealer. The back ones are part of the rear leaf springs, but I believe they are also called bump stops.
It seems the cure for this problem is the (V & B code springs mod) the distance between the frame and the axle isn't sufficant enough and they constantly pound the bump stops, which is part of the hard bounce going over speed bumps and like.
Hope this helps.
Old Sep 6, 2008 | 11:00 PM
weekendwarriorfsw32
Master of Strokes
Thanks and yes its a 2001 X with the 7.3 sorry I should have said that
Old Sep 18, 2008 | 07:49 PM
betontheturtle's Avatar
betontheturtle
energy suspension make a polyurethane bushing/and bump stops for these beasties cheaper and better than stock
Old Sep 18, 2008 | 08:34 PM
71-4R3SONS's Avatar
71-4R3SONS
For the rear ones... Install "Landyot's Radius Rods". During installation of the RR's you must cut off the axle anti-wrap leaf extension. That way you don't have to buy the rubber bump stops.
I know how much you like adding mods to the 01.
FYI...
The thing you are calling an overload spring has nothing to do with the spring pack, or very little at least. It is there to prevent spring axle wrap due to the relative weak rear spring FORD put on the X.
Old Sep 18, 2008 | 08:52 PM
71-4R3SONS's Avatar
71-4R3SONS
Here's a link that will give a better explaination:
Rear axle wrap info
Old Sep 19, 2008 | 12:50 AM
Monsta's Avatar
Monsta
Sit. Stay.
Those bumpers for the snubber leafs are a dealer only item.
RacinNdrummin
2196
Oct 20, 2018 05:56 PM
cleatus12r
101
Mar 12, 2015 10:47 PM
chefwita64
Dec 30, 2012 09:52 PM
duck fan
24
May 14, 2012 12:42 PM
thunder31634
Oct 12, 2010 06:01 PM
