i want to put new flooring in my 68, not rug but the other stuff(cant think of name right now) its a work truck so i want to be able to clean it out etc. who sells premolded rugs and matting?
LOTS of places do, many of the sponsors (links the left) have them also LMC has them, many people dont like LMC but i have had good luck, also i think i got mine from California Mustang, or was that my dash pad i forget.
yeah the dash pad came from Cal Mustang and my carpet was from LMC, both worked out great!
If you want rubber floor matts I never found a full floor natt like the original. All of them stop at the front of the seat. I ordered one from J C Whitney because the picture showed it going down both sides of the seat, but when it arrived it was cut off at the seat like all the others. I ended up installing a full length carpet.
My 68 has full carpet. (had to shampoo it with a garden hose) and then
vac't it with a shop vac to get the water out of the car Er uhhh
I mean CRAPET. For 39 yo. its in remarkable shape. But when it wears out
I am going to put Rhino liner in there. That way water wont hurt nothin'
I just hose it out.
very cool and you also answered my next question, how to install speakers in my cab without ruining doors, the guy before just stuck them behind the seat by the magnets,i need to hear my Waylon and DAC goin down the road. thanx
if you are takling about the head liner you might want to call before and see if they have it. I tried to buy it a few years back and they said they were not selling it anymore....
One other thing You can do to eliminate sound in cab, Do what I
did with ay first truck running tires that resonate thru the frame
right into the cab.... I took the sidewall out of a tire, And put it
between the rear axel and thr springs. Wala! Nice and QUIET
Mind you the side wall cane from a 13 inch tire. It's thin and easy
to install. If you are worried about ground run a wire to the frame
from the axel
