2002 Explorer 4WD Light Flashes
Old Sep 4, 2008 | 10:06 AM
jeepnutz's Avatar
jeepnutz
I own a 2002 Explorer and the 4WD Light flashes and it dosen't seem like it engages the wheel drive. Any body have an idea of the problem?
Please help I live in snow country and winter is approaching......
Thanks
Old Sep 4, 2008 | 02:38 PM
jk080's Avatar
jk080
Transmission Rebuilder
You are going to have to get it scanned. There will be a code that help point you in the right direction.
Old Nov 24, 2008 | 07:26 PM
danielle1001's Avatar
danielle1001
I seem to be having a similar problem with my 02 sport trac, but my 4wd is actually on, and stuck on 4wd low... i cant figure out how to switch it back because the switch isnt working... and i cant really drive it in 4wd low, any suggestions??
Old Nov 24, 2008 | 07:36 PM
antony25's Avatar
antony25
You may have a bad 4x4 module. Common problem on '02 explorer.
Old Nov 24, 2008 | 07:39 PM
danielle1001
i have a feeling its going to be costly to fix!
Old Nov 25, 2008 | 01:10 PM
pbjohns's Avatar
pbjohns
If it is the 4x4 module, it will cost about $200.00. Good luck
Old Nov 25, 2008 | 03:52 PM
danr1's Avatar
danr1
Doesn't "repair" the problem but reach under it and try taping on the shift motor with a hammer or tire iron while trying to shift back to two wheel, That might/should get it out of low range and back into two wheel so you can get home/use it when it happens. Done it a few times with good results.
If that does work you probably just need the shift motor removed cleaned and lubed or if its bad enough just replaced with a new one. Dirt water and wear makes em tend to hang up.
8brian1
20
Dec 30, 2016 08:21 PM
Primerranger
Mar 12, 2015 06:11 PM
cat2000zrt
Feb 14, 2011 03:50 PM
Explorer Freak
May 5, 2010 08:34 PM
jeepnutz
General Diesel Discussion
Dec 5, 2008 10:54 AM
