99's front end is squeaking.
Old May 4, 2010 | 10:40 PM
Explorer Freak's Avatar
Explorer Freak
A few weeks ago, I posted a question about the 4wd high and 4wd low lights flashing and a squeaking noise coming from the front end. I took it to the mechanic and he cleaned the 4wd actuator motor and the contacts on the motor. The lights haven't flashed since then, but the squeaking continues. Is this a normal noise? My Explorer has the Control-Trac (permanent four-wheel-drive).
Old May 5, 2010 | 03:23 AM
Moto Mel's Avatar
Moto Mel
Where is the squeek coming from? Front end,T/case? Where? There are many places that can have squeaks coming from them.
Need Input.
Old May 5, 2010 | 01:02 PM
aquanaut20's Avatar
aquanaut20
You are miss informed, Control-Trac is NOT (permanent four-wheel-drive)
Change or clean and lube the front sway bar bushings to quiet the noise..
Old May 5, 2010 | 08:34 PM
Explorer Freak
It sounds like it's coming from the frontend or transfer case.
Ok, in the owner's manual (yes, I've read it) it says that there is Control-Trac, 2WD, and AWD (only on 5.0 models). I have the "shift on the fly" **** on my dash (4WD Auto, 4WD High, and 4WD Low). My understanding was that when it is in 4WD Auto, it's still in 4WD but it only engages when it senses that the frontend is slipping.
Is that Control-Trac?
Diesel Man 03
Dec 23, 2016 06:37 PM
pfb
Apr 2, 2011 08:12 AM
rustyolred27
Mar 25, 2007 12:02 PM
franklin411
13
Oct 29, 2003 07:30 PM
true blue
13
Apr 6, 2002 11:12 PM
