6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
First real pull.....impressed
Old Aug 31, 2008 | 02:22 PM
jasfaa's Avatar
jasfaa
The 03 motor had the same rating as the 05 and later vehicles but when dynoed the 04 and earlier motors had more power at the rear wheel. Ford changed changed the scheme in late 04 or 05. I have an 05 still and it cannot pull like my 04 did and the 05 pulls right along with my 08. the 04 would have pulled away from it. Look at the dyno numbers in my attachments page and compare the rear wheel numbers to the numbers people are getting on the 6.4 without double stacking. I had a Banks kit which did not give you the most power compared to others out there but my numbers are higher than most of the dynoed results on the 6.4 I have seen so far. makes me go HMMMMM....
Old Aug 31, 2008 | 02:26 PM
jasfaa's Avatar
jasfaa
You did answer the question I just did not elaborate. Thanks again and here was my line of thinking. When these things go into regen you lose power so I am not sure how we are not seeing eye to eye on this. I realize when it is not in regen you have full power. I go into regen alot here due to the traffic, hills and people that just can't drive the speed limit or even close to it. I realize that comparisons between Seattle's poor road infrastructure and wide open texas highways are not possible. This is where my mind was when I was asking.
vincenthp
Aug 31, 2009 08:08 PM
a64armt
Aug 19, 2008 04:50 PM
a64armt
Aftermarket Products
Aug 1, 2008 02:18 PM
a64armt
Jun 13, 2008 02:47 PM
a64armt
Jun 7, 2004 01:57 PM
