1978 - 1996 Big Bronco
Electronic Transfercase Controler
Old Aug 28, 2008 | 10:40 PM
rudedogii's Avatar
rudedogii
I have posted some questions about the BW1356 Electronic Transfercase on an other thread. Some people are so rude!
So my question was does anybody know the name of the electronic transfercase control module?
I was trying to shop on-line to get a price range for a possible replacement.
What is this part listed as in a catalog? I could not find a listing.
1983 Ford Bronco Spare Parts picture | SuperMotors.net Thats the part right there.
Old Aug 28, 2008 | 11:00 PM
JasonCorvallis's Avatar
JasonCorvallis
I would write down the serial and engineering numbers and call the ford dealer. they may be more expensive but if they dont have it they will do the leg work to find one for you most the time. I looked for one for mine to and had a hard time finding one.
Old Aug 29, 2008 | 07:31 AM
alxsnmr's Avatar
alxsnmr
What year is the truck it is in?
You should be able to scrounge at the local pick n pull as that was somewhat used often on the 1/2 tons. Good luck though!
Old Aug 29, 2008 | 12:06 PM
Kemicalburns's Avatar
Kemicalburns
wasnt trying to be rude, it just makes it easier for us to help you is all.
Personally i would locate a manual Tcase to swap in its place. the pushbutton tcases are notorious for having these problems. you can fix it and run into these issues again in 6months.
Old Aug 29, 2008 | 04:30 PM
NWBronco's Avatar
NWBronco
Right on. What makes you sure it's the controller? I've seen too many motors and no controllers fail. I did see the shift motor wires ripped from under the rig in a stump patch one time, though.
Old Aug 29, 2008 | 08:37 PM
rudedogii's Avatar
rudedogii
Normaly I can hear relays click and the trasfercase shifts.
But when it dosen't shift I dont hear nothing. My quess is the dash button or the controler has gone bad.
My big problem is sometimes it works and sometimes it don't. I figure next time it dont work I will have to pull the button off the dash and manualy jump the wires.
If that dont work I can rule out the button.
Old Aug 29, 2008 | 08:47 PM
rudedogii's Avatar
rudedogii
Also if you take a look at the controler at this link 1983 Ford Bronco Spare Parts picture | SuperMotors.net
You notice a test button and red LED. I read someware on line the test procedure. I cant remember it now. Does anybody know?
Old Sep 1, 2008 | 10:51 PM
rudedogii's Avatar
rudedogii
Transfercase Control Module TEST
Well it has taken me sometime searching the web but I found what I was looking for.
I'll put the link here for anybody else with transfercase shift problems.
1989 Ford Truck F 250 4WD Pickup V8-460 7.5L - Diagnosis of the Electric Shift 4 X 4
Old Sep 2, 2008 | 09:07 AM
alxsnmr's Avatar
alxsnmr
I had the 'dead' t-case switch, but I pulled it out of the foot well and found the white button to push for it to start working again. It was a cold snowy day in st louis and I was glad I didnt need the 4WD because it would not have been a nice day. This last winter I have not had a bit of trouble with it even with the more unusual amount of snow, but it was fun plowing through the snow. Look at me bragging about 18 inches of snow where others in this country would call that a light dusting of snow!
Old Sep 3, 2008 | 06:33 PM
Goodsath's Avatar
Goodsath
The relays could be bad
I have had the same issue. The control box stopped clicking when I hit the buttons. I had to pull the control mod out and fount the two relays. I desoldered them and brought them to the local electronics store. Got two new ones and soldered them back on the control board. The problem fixed a year later the t-case motor contacts burned out. It was replaced, what a head ache. I was under there with a pair of plyers manualy shifting the thing in and out of 4 wheel. They need to make a manual adapter. Good luck
Old Sep 3, 2008 | 07:10 PM
rudedogii's Avatar
rudedogii
Just for laffs. If Ford put a manual shift transfercase how could they compete with Range Rover and Hummer?
I dont think many women like to get out of there vehicle, turn there hubs , and then still have to shift the transfercase.
Old Sep 14, 2008 | 11:20 AM
rudedogii's Avatar
rudedogii
transfercase trouble shoot
Well I finally got around to trouble shooting the transfercase. I checked the motor position sensor and found one circuit in the open position when it should have been closed.
I then pulled out the sensor. Manualy rotated it and rechecked the circuits a again. Every circuit opened and closed as they should. Put everthing back together and now it works!
If this happens again I will just replace the motor/sensor assembly.
I made a video of my trouble shoot. YouTube - Bronco Transfercase
AbandonedBronco
754
May 31, 2019 09:39 AM
Evan_P
62
Apr 12, 2019 03:10 AM
Miketnf150
Ford Truck Parts for Sale
85
Oct 6, 2015 04:27 PM
OX2
Aug 24, 2012 06:33 AM
