Will a Bad Vehicle Speed Sensor Cause You to Stall?
Old Aug 28, 2008 | 07:01 PM
  #31
3BadBirds's Avatar
3BadBirds
Thanks Bill!
You were probably the person who gave it to me in the first place!
Old Aug 28, 2008 | 08:10 PM
  #32
jacked87f250's Avatar
jacked87f250
My truck was doing the same exact thing. I have an 87 f-250. My problem started out as that an got worse! Is it carburated? My problem ended up being that my gas lines were sucking air and causing the truck to faceplant.
Old Aug 28, 2008 | 09:33 PM
  #33
3BadBirds's Avatar
3BadBirds
No carb on my 88 F250 351w - its EFI.
I did notice this evening that after it died the fuel gauge needle swung way past the "F"ull mark for awhile. Ever since I got my truck that needle has pointed to "E"mpty. Maybe it's another sign of some wiring gone askew. At this point I'm hoping for any type of fix that doesn't involve dropping a tank....
Old Aug 29, 2008 | 07:41 AM
  #34
subford's Avatar
subford
You have the Magnetic Fuel Gauge, so past way past the "F"ull mark is an open circuit. An short would be the other way, way past the "E" mark.
Old Aug 10, 2020 | 08:20 AM
  #35
Garnet Prescott's Avatar
Garnet Prescott
2nd Gear
I have had that exact thing on my 2005 V10 Excursion.
I have an intermittent problem whereby my engine will suddenly cut out on my 88 F250 (351 / C6). It happens almost as if someone has just turned the key off. She usually starts right up after the stall although it sometimes takes a little extra throttle to keep her going initially. I checked the codes and got a 29 in memory which translates to a problem with the Speed Sensor.
Can a failing speed sensor cause my stalling problem. I thought the problems with this sensor primarily affected your cruise control which, by the way, my truck does not have. My speedo also seems to be working fine.
Any help would be appreciated!
Thanks!
Code reader said bad speed sensor. Changed sensor and all was good. No more codes and no more stalling.
tlcarrig
Aerostar
Jul 28, 2013 08:18 PM
LTCPipkin
Aerostar
23
Dec 4, 2008 01:21 AM
Fordenthusiasts
Apr 17, 2007 08:06 PM
bbor62
1983 - 2012 Ranger & B-Series
Jun 21, 2004 11:22 PM
RC46
Sep 23, 2003 09:29 PM
