Sponsored by: Real Truck
PA system help
Old Aug 27, 2008 | 09:44 PM
motometal04F350's Avatar
motometal04F350
PA system help
just picked up a cobra cb radio/pa system. after pondering under the hood for a while on a good spot to mount the pa loud speaker, i didnt really find a good spot. any thoughts? its a 5 inch speaker if it makes a difference.....
Old Aug 27, 2008 | 09:55 PM
motometal04F350
btw its a v10
Old Aug 27, 2008 | 10:12 PM
jerzydiver's Avatar
jerzydiver
I mounted mine to the bottom back side of the lower radiator support.
Old Aug 27, 2008 | 10:18 PM
motometal04F350
the elements didnt short it out or anything did it?
Old Aug 28, 2008 | 05:42 AM
ReAX's Avatar
ReAX
Firstly are you using an automotive PA speaker? I tried an outdoor speaker once and I had to add an amplifier to drive it.
Old Aug 28, 2008 | 09:12 AM
Help I M Stuck's Avatar
Help I M Stuck
I got one of them BIG warehouse speakers mounted to the under side of mine..to the frame rail.
Old Aug 28, 2008 | 03:40 PM
jerzydiver's Avatar
jerzydiver
no i bought a ASPC20
20W 6”Weatherproof Amplified P.A. Speaker
Old Aug 28, 2008 | 03:48 PM
function12's Avatar
function12
I would say down by the frame rail on the passenger side. Just make sure you point it down a little so the water and crap will drain. No problem with my air horns down there.
Old Aug 28, 2008 | 05:01 PM
DAFBFD58's Avatar
DAFBFD58
I have a whelen 100 watt horn mounted to the floor of the passenger area right behind the plastic inner fender. My air horns are on the other side on the fram rail pointed a little bit down to keep water from staying in the horn.
Br1
Jul 2, 2013 11:17 AM
DSMMH
Feb 15, 2010 10:23 PM
k_kindig11
27
Jul 22, 2005 11:43 PM
ejbaumruk
Apr 11, 2004 01:19 PM
rickbow
Mar 31, 2004 12:10 PM
