PA system?
Old Apr 10, 2004 | 11:19 AM
ejbaumruk's Avatar
ejbaumruk
PA system?
Does anyone know what all I need to do in order to install a PA system on my '79 F-150? I'm assuming I'll have to put in a CB radio and speaker somewhere....but where? And how? Thanks!!
Old Apr 10, 2004 | 12:18 PM
MG86TA's Avatar
MG86TA
You need the CB Radio.. You can hook the power to the cigarette lighter, the ground u can screw into the floorboard or firewall. You need a speaker, which a 50watt one from Radioshack is like $40. You also need a plug to hook the speaker cable from the Speaker to the CBRadio. I have one in my truck, if u need pics i can take them so you can see where i mounted everything.
Old Apr 10, 2004 | 12:26 PM
mrsuperman15's Avatar
mrsuperman15
would you please post the pics? i am interested in doing this also in my 79 4x4, can i wire the cb directly to the battery? i ask because my cigarette lighter doesn't work
Old Apr 10, 2004 | 12:44 PM
FordPickup460's Avatar
FordPickup460
For the speaker there are special speakers just for a pa speaker, mine was $12.99 at a local 4x4 shop. Also, when you get a cb, make sure it has the pa ability, most of the $35 ones do not. Do not plug the pa into the external speaker hole. I mounted my pa speaker on the radiator support pointing towards the firewall. Most of them are all weather.
Old Apr 10, 2004 | 01:53 PM
Mil1ion's Avatar
Mil1ion
For mine, I bought a floor mount and screwed it to the floor.
IMO, It's the only way to go
Get a speaker horn & the PA system just plugs into the back of the radio as long as that radio has that option.
Also, The topic is not 73-79 specific and will be moved to Audio forum.
Old Apr 11, 2004 | 10:21 AM
MG86TA's Avatar
MG86TA
yeah just gimme a little bit i will grab my sis' digital camera and take some..
For some information.. yeah you can wire it directly to the battery, just takes longer wire .
Old Apr 11, 2004 | 01:01 PM
FordPickup460
If you wire to the battery, dont forget to turn the cb off when you park the truck, I found that out the hard way
Old Apr 11, 2004 | 01:19 PM
ivanribic's Avatar
ivanribic
And don't forget to put an inline fuse on that wire, close to the battery. Or you can carry a fire extinguisher . . . don't ask.
jufam44
6.7L Power Stroke Diesel
Dec 6, 2011 09:41 PM
motometal04F350
Aug 28, 2008 05:01 PM
88FordF-150
Pennsylvania Chapter
157
Oct 17, 2006 12:25 PM
jayhawk137
17
Sep 25, 2003 11:24 PM
stover007
15
Dec 16, 2002 06:36 AM
