Trans ?
Old Aug 26, 2008 | 04:54 PM
aklim's Avatar
aklim
Originally Posted by jesse5
You can add a ground strap yourself very inexpensive. With all the solenoids in today's trannies it is probably not a bad idea. Remember that your tranny and engine mounts are usually insulated with rubber. Make sure your engine has a good ground strap. There are problems when someone replaces a drivetrain and forgets to reconnect the ground to chassis.
I would think that the engine is somehow grounded, wouldn't you? Since the tranny is attached to the engine, doesn't it stand to reason that the tranny is also grounded?
Old Aug 27, 2008 | 10:20 AM
brian42's Avatar
brian42
Veteran: Navy
Yes, but with everything connected with gasket/gasket material. Include all of the anti-seize on the bolts and you might not have a solid ground. By "strapping" the tranny case you ensure a good solid ground. Not to mention that you want a ground to be as short as possible.
It's one strap, you'll never see it and it doesn't hurt performance or ground clearance.
You'd be surprised at what a weak (or long) ground can do.
Old Aug 27, 2008 | 09:53 PM
Dmax Stroked 00's Avatar
Dmax Stroked 00
If i were to add one myself where should i put it
Old Aug 27, 2008 | 11:08 PM
aklim's Avatar
aklim
I would put one up on the bellhousing bolts and run it to the engine ground. Why don't you give BTS a call and see if he thinks ot might help? 1-870-422-3673. Even if you don't buy anything from him, if you are willing to hold till he can get to you, I'm sure he will answer your question. They are very busy. I was there and saw no less than 5 stickys that he had to get to call back at any time.
Old Aug 28, 2008 | 06:18 AM
jesse5's Avatar
jesse5
$5 is not too big a deal. I recently put an engine in and forgot the ground strap and it would not start until I installed it. If it is an electronic automatic transmission I would ground it.
bkeese
16
Oct 15, 2013 11:06 PM
5.0 Heaven
Escape & Escape Hybrid
May 17, 2012 06:09 PM
bergy 2000
Apr 30, 2011 02:35 AM
Franko72
582
Sep 25, 2010 04:23 PM
njstevens
Mar 22, 2010 08:58 AM
