Hey all, I bought my truck about a month ago with 150k miles on it. I am not sure about the previous owners maintenance so i figured it would be a good idea to flush the trans. The mechanic i talked to told me that for some extra $ he would re ground the trans. He said that Ford does not ground there trans good enough and that it adds to the early failure of a lot of them. Has anyone heard of this or is he feeding me a line of BS to try and take some more of my $. Maybe it is common to do and i just have never heard of it. I dunno, i am new to this diesel thing and tryin to learn.
Not sure on the ground thing. Never heard of it. But i don't know much. But i would do the tranny maintenance. Pull pan,new filter, dump TC. the whole nine yards. I had my serviced for $119. Oil/filter/labor while i was having the TC changed. If your not having any trouble i would just do the maintenance.
Thanks Dan. I still plan on the maintenance but i had never heard of this grounding thing, sounded kinda fishy to me. Hopefully someone that has heard about can help.
Is it were they take a black wire & self tap screw to the bottom of the pan and run it to the frame or the negative post on the battery? And charge you $150?
Maybe someone else will have a grounding answer. But i never heard of it.
Ya that sounds about right. LOL I dont have any idea really he just said he would re ground it better. whatever that means
This method does not stir up stuff that could be in there like a flush machine does that could lead to new problems, Correct?
Also i have read use merc 5 dont use it only use merc dont use it and on and on. What fluid do i use since i do not know what is in now and i assume some of it would mix with the new doing it this way.
Thanks again
Dustin
I think that is an excellent write up. I've done it many times. It doesn't stir up things in the trans, but then again, neither does a flush machine. Both the flush machine and that procedure change the fluid in the same way.
When it was written MERCON V was a no-no for the 4R100. Ford changed MERCON V and dropped MERCON, so MERCON V is now the right fluid.
Thanks again
Dustin
Ford recently approved Mercon V in the 4R100. I used Mobil 1 synthetic ATF. It's not cheap, but it's cheaper than a new tranny. Definitely DO NOT get your tranny flushed! I've read many a post where they did this and within a year the tranny died. I only use the above article and it works great (albeit a little messy).
166K and still on the original tranny (knock on wood).
A couple of things. That is an old wives tale. Secondly, if you flush your trans way after it is due and you take poor care of your vehicle, you should not be surprised if the trans breaks. Usually people have a little issue with the trans and flush it in hopes of it fixing the trans and when it fails, the flush broke it.
You can add a ground strap yourself very inexpensive. With all the solenoids in today's trannies it is probably not a bad idea. Remember that your tranny and engine mounts are usually insulated with rubber. Make sure your engine has a good ground strap. There are problems when someone replaces a drivetrain and forgets to reconnect the ground to chassis.
