head bolt ?????'s
Old Aug 23, 2008 | 10:10 PM
dieselaholic's Avatar
dieselaholic
head bolt ?????'s
Im rebuilding a 351w motor from a 92 truck. Chiltons manual doesnt say anything about applying oil or sealant or lock tite to any head bolts. Ive put enough bolts in things before to know that you always put something on them, what is reccommend?
Old Aug 23, 2008 | 10:20 PM
goodB0Y's Avatar
goodB0Y
I just looked up the repair procedure using ALLDATA and it says nothing either... mabe nothing is to be used. I do know that using a bottoming tap to clean the threads is allways a good idea. And I would think that a light oil should be used but I'm not sure...
Old Aug 23, 2008 | 10:28 PM
mcanik's Avatar
mcanik
Dry and clean bolts for head bolts is what I was taught. Gives the proper tourque readings when tightened.
Old Aug 23, 2008 | 10:29 PM
quicklook2's Avatar
quicklook2
you must use new bolts.
no sealant or anything.
Old Aug 23, 2008 | 11:36 PM
quaddriver's Avatar
quaddriver
it doesnt?
IF the bolts extend into the cooling jackets you MUST use PST (or equivalent) or elee they will leak. A little motor oil dunk for the others to keep them from galling
and under the heads, use a bit of sealant - the reason being it lubes the head (no that is not pornographic) so when you torque it, it does not stick and give a false reading.
It really said to use nothing?
Old Aug 24, 2008 | 01:42 AM
quicklook2's Avatar
quicklook2
looked in my ford service manual, twice.
can't find anything that says to do anything except torque.
edit: i am going through he service manual. page by page, i found that the 300 six section says to coat threads of bolts with engine oil.
still looking for v8's.
edit: it only says to do this:
1. clean the cyl head
2. do not apply sealer to composition gasket.
3. cyl heads are tightened in 2 steps for 5.8 3 steps for 5.0
5.8: all bolts to 95-105 lb-ft
all bolts to 105-112 lb-ft
5.0: 24-35 ft-lb
45-66
turn all bolts in sequence an additional 85-95 degrees.
sequence is
9 5 1 3 7
10 6 2 4 8
no mention of oil on bolts.
i hope this helps.
i am trying to watch usa basketball win a gold metal so i hope i got this straight.
Old Aug 24, 2008 | 08:25 AM
12secondstang's Avatar
12secondstang
Originally Posted by quaddriver
it doesnt?
This is the way I have always done this. Sealant on the lower bolt threads and oil under the head of each bolt.
Old Aug 24, 2008 | 08:28 AM
quicklook2's Avatar
quicklook2
the 300 six part talks about 2 bolts like that but the 351/302 does not.
Old Aug 24, 2008 | 09:14 AM
Conanski's Avatar
Conanski
It's always a good idea to put some sealant on the lower(outside) head bolts as they go right into the water jacket. The inside bolt holes are blind so these should get oil. Other bolts that should get sealant are the water pump bolts around the outlets in the block, and the flywheel/flexplate bolts in the crank, these too go all the way through and can be a source of leaks.
The "How to rebuild small block Fords" paperback I have mentions what all these bolts should get as far as sealant and lubrication.
Only those blocks with torque to yield head bolts require new ones when the heads are removed, and I don't believe any of the small lock motors used these.
Old Aug 24, 2008 | 09:18 AM
quicklook2's Avatar
quicklook2
it was late and i forgot to mention that the ford service manual did not say to use new bolts.
i was watching usa basketball win gold and i was very excited.
Old Aug 24, 2008 | 11:12 AM
dieselaholic
My bolts seem to be in great shape and not rusty at all, actually black as the day they were new. I think i might put sealer around on the threads just to be sure. I dont think it would hurt anything anyhow. Im not sure what id do if it werent for you guys. I know my wife would go nuts
Old Aug 24, 2008 | 01:04 PM
quaddriver's Avatar
quaddriver
Thats the same book I use - I looked at the service manuals and it lists as the other posters said - I wonder why leaks are not reported.
FYI - bolts that use an angle gauge after max torque are 'TTY' (torque to yeild) bolts. use them - replace them - old ford bolts IIRC are not TTY and the stuff you can get thru summit are not ttys (unless specified)
the 'yield' is 1/4th of one thread of whatever thread count you have (i.e. 16TPI = .25 * .0625), expressed in thous)
cookingguy
Nov 30, 2014 11:52 AM
roshan
Sep 3, 2013 08:46 AM
dulockdrumheller
Apr 13, 2011 02:42 AM
turnrjr
Dec 6, 2008 08:51 PM
90F250351
Dec 12, 2006 04:08 PM
