Has anybody wired the dome light(s) through a toggle switch or factory upfitter switches?
I have a 2003 Super Duty crew cab - I'd like to turn the dome lights off if I have the doors open for extended periods.
Not as easy as you would think. You have a interior lights relay in the instrument cluster. See if you have a fuse #35 in the underdash fuse box for the courtesy lights. Leaving the fuse box will be a black/lightgreen wire. If you could find this wire, and add a switch to it, that would kill power to the relay, which should kill the lights. You might want to pull the fuse first, and see if that kills the lights.
