dome light wiring question
Old Apr 15, 2016 | 07:50 PM
mrstephs's Avatar
mrstephs
hi guys..i bought a midfifty dome light and having problems wiring. installed a centec wiring harness with a gm switch.Dome light only has one wire.when hooking up to door jam switches everything works until I switch headlight switch to left and then blows fuse everytime.Is it because its a ground and dome light is only one wire.Can I use switch to turn on or have to just get switch that goes on dome light.thanks
Old Apr 15, 2016 | 10:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Read this past thread:
https://www.ford-trucks.com/forums/1...ns-please.html
Old Apr 15, 2016 | 10:20 PM
drptop70ss's Avatar
drptop70ss
GM setup should be like this
Since you only have one wire on the dome light switch I guess you are supplying 12v through the jam switches and using the cab as ground. GM supplies 12v all the time and sends the ground from the jam switches and the headlight switch. Putting 12v on the jam switch / headlight switch will blow the fuse because you are putting the hot wire directly to ground.
Old Apr 16, 2016 | 08:13 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I don't remember what kind of dome light I used but what I did was insulate the dome light from ground and hot wire it. Use the terminal off the switch for ground. Worked for me.
landers0440
Apr 15, 2019 09:10 AM
Bluey Zedoff
Nov 21, 2013 12:11 AM
Joe T.
Nov 8, 2011 05:29 AM
mkrog
Sep 29, 2011 09:01 AM
btacarlton
22
Mar 21, 2006 04:06 PM
