Another Instrument Panel Question
Old Jul 29, 2014 | 06:31 PM
wtx66f100's Avatar
wtx66f100
Started having fuel and temp gauge problems a while back and replaced the constant voltage regulator which seemed to fix the gauge problems but had no dash lights. Replaced the printed circuit board for the instrument panel this past weekend and everything seemed good. Gauges and idiot lights working ok and dashlights working so I can see the speedo at night.
Today driving it to work the gauges would not work and I honestly can't say if the alternator and oil pressure lights came on before I started it up. I was not about to run blind so I headed back to the house and parked it for the day. When I got home this evening I reached under the dash to make sure the plug was firmly seated into the panel/circuit board. No play at all and it seemed secure. When I turn the ignition on the fuel gauge very slowly moves and finally shows my fuel level.
It has me wondering if the constant voltage regulator I put in is bad or what else I can check on this problem? Kinda scratching my head at this point.
Thanks
wtx66f100
Old Jul 29, 2014 | 11:08 PM
orich's Avatar
orich
I had those type of things happing a few times and notice my key was not in the run position so turned the key a little to the right and bingo everything was working again.
So this may have been your problem with the ign. key not turned on all the way.
Some yrs later, I replaced the whole key & ignition switch. Never happen after that.
Orich
Old Jul 30, 2014 | 06:48 PM
wtx66f100's Avatar
wtx66f100
Thanks orich. There is some play in the ignition switch and I bet that is probably what caused the problem the other day.
wtx66f100
Old Jul 30, 2014 | 08:06 PM
JEFFFAFA's Avatar
JEFFFAFA
wtx66f100
Where there's Play.....ya gotta Pay.
Old Jul 30, 2014 | 08:17 PM
wtx66f100's Avatar
wtx66f100
You got that right JEFFFAFA but that aint a bad thing. Working on this old truck is enjoyable for sure.
Matt1966
19
May 20, 2017 08:55 AM
iggybob44
Dec 30, 2013 07:00 PM
bumblebee902
Aug 20, 2010 08:30 PM
howlingwolf
Oct 15, 2007 04:14 PM
captnmike
Jul 19, 2004 02:33 AM
