oil pan help
Old Aug 18, 2008 | 01:51 PM
PLMCRZY's Avatar
PLMCRZY
Question oil pan help
I have not posted in a long time,sorry my project is very slow.But anyway to my latest problem,I'm putting a 68'390 in my 66 swb and I need a rear sump pickup and pan does anyone have this or can help me find it.
Old Aug 18, 2008 | 08:03 PM
Customcab's Avatar
Customcab
No 100% sure; but I would recommend posting in the engine forum and ask if a 360 pan from certain other years and even car's would work. The dip stick location is another though into cross referencing these potential pans. Your local salavge yard is a go starting point as well.
Mitch
Old Aug 19, 2008 | 10:51 AM
bertha66's Avatar
bertha66
Why do you need a rear sump pan? And what was on the old engine. The 352's that came in the 66 2wd trucks had front sump pans and the 4x4's had the rear sump. If you go with the rear sump you will need the oil pump pick up tubeand the center main bearing cap bolt that holds it in place.
Old Aug 19, 2008 | 12:13 PM
Redmanbob's Avatar
Redmanbob
I see the 4x4 in the yards from time to time. However with my luck someone has always already gotten to the pan/pickup/bolt LOL.. I think a trip on an off day is in order you might get lucky. 45.00 out the door, or there is epay.. but they tend to go for a pretty abe¢
Old Aug 19, 2008 | 12:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The stud for the pickup tube is still available from Ford. The MSRP is $13.57.
The exact same stud (D6TZ6345A) fits all the FE engines and 1981/96 F150/350 351W w/4WD. (D6TZ-6345-A replaced C6TZ-6345-A).
The FE oil pan used on 1965/66's with 4WD is not the same as the type used 1967/76. Ditto for the 2WD pans.
Old Aug 19, 2008 | 05:17 PM
bertha66's Avatar
bertha66
The oil pump pick up is available from NAPA for under $30. Oil pan is going to be a wrecking yard find.
Old Aug 19, 2008 | 05:43 PM
BobbyFord's Avatar
BobbyFord
Won't he need dipstick and tube for 4X4 pan also?
Old Aug 19, 2008 | 06:05 PM
bertha66's Avatar
bertha66
Yes, forgot to say that. The tube is in the driver Side of the pan.
Old Aug 20, 2008 | 08:59 AM
PLMCRZY's Avatar
PLMCRZY
Thumbs up thanks
Thanks so much for the response,I started calling salvage yards and the second one I called had the pan,pickup,screen and dip-stick for 150.00.I will try to put updated pics very soon!!Again,thanks alot guys
jhaas63
Feb 3, 2013 07:58 PM
abelmoreno
Feb 19, 2008 11:42 PM
oxfordgt
Nov 7, 2006 09:16 AM
rusmel
1983 - 2012 Ranger & B-Series
Aug 18, 2005 03:17 PM
ClatonK
Jan 9, 2004 12:08 AM
