trouble removing oil pan on 1953 flathead
I'm in the middle of a project and need some help men.
I wanted to change the oil pan gasket in my truck. I have a service manual and am Following it. Problem is...I cant actually get the pan off. My truck is one where it does not have the access pan. What trick dont I know? Reason for dropping the pan is to clean out the sludge.
Yep. Took care of that. It seems like the tie rod is in the way Of the pan dropping. I really don't want to take that off because I just had an alignment.
So it's off the engine, but you can't get it out from under? Jack under the frame, until the wheels are just about to come off the ground.
If you have a car style pan (no cleanout), the oil pickup has to pass thru a hole in a windage tray that is about 3 - 4" below the pan rail. So you have to drop it straight down until it clears that.
ol' yeller1
10-24-2004 10:56 PM
