engine id
Old Aug 16, 2008 | 09:12 PM
shelby1965367's Avatar
shelby1965367
Question engine id
Hi , I just purchased a new to you 56 ford f 100, it has a 6 cylinder motor in it and I want to find out what it is. The casting on the side of the block reads c3 ae 6015 ac then on the side of the block near the water pump there is a flat spot that has 3c27 on it. The intake manifold bolts on the side of the motor, the valve cover has bolts on the side of it not in the middle, I think it is a 63 223 motor, how can I be sure? thanks for any replies John
Old Aug 16, 2008 | 09:27 PM
havi's Avatar
havi
I'll have the Roast Duck
sounds like one to me. If the exhaust manifolds are on the driver side, I believe it to be just that.
Old Aug 17, 2008 | 02:01 PM
Col Flashman's Avatar
Col Flashman
Pretty much looks to be that way.
Old Aug 18, 2008 | 02:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
3C27 = cast on March (C) 27, 1963 (3). The same block was also used in 1964.
429unibody
Sep 8, 2009 10:40 AM
gliderdad
Mar 27, 2009 11:40 PM
pcmenten
Jan 5, 2007 11:26 PM
jharvey3
All Things Towing
Jan 26, 2005 10:40 PM
roscoe
Mar 18, 2004 03:28 PM
