Hitch ratings
Old Jan 26, 2005 | 07:30 PM
jharvey3's Avatar
jharvey3
Hitch ratings
Please forgive me if this has been covered, I'm not getting along with the search engine
What determines the weight rating of a class 3, 4 or 5 hitch? Is it the receiver itself, the ball mount, or a combination of the two? My ball mount has stamped into it: 600lb tongue weight and 6000lb tow capacity. My dad's has 500lb tongue and 5000lb tow but the recievers look identical, 3 bolts per side attaching to the frame, same physical dimensions just a different brand name.
Thanks for any info
John
Old Jan 26, 2005 | 07:52 PM
baitmaster's Avatar
baitmaster
yikes
Going by what my hitch info says, it is a combo of both. I guess you could weld a class 5 hitch on a Yugo, but then what happens? A buddy of mine just had a friend stop by his garage the other day, and dropped two pc's of a 2" receiver on the floor. It had snapped in two right at the bend by the ball mount. Not even on the weld, it was the metal itself. He was starting to pull a trailer that had a big rock wedged in between the two tires on a dual axle trailer. Put a big truck with a big trailer that is "stuck" and gas it, something will give somewhere.
Old Jan 26, 2005 | 07:57 PM
Steina's Avatar
Steina
CO River Rat
John -
The receiver hitch is the limiting factor; you can buy ball mounts with higher specs. Plus, some hitches can be used at max ratings only with WD.
Steve
Old Jan 26, 2005 | 08:04 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
the receiver hitch, even though they might have the same physical dimensions, the grade of steel and thickness of the steel will make a lot of difference in the class of tow receiver.
Old Jan 26, 2005 | 08:26 PM
jharvey3's Avatar
jharvey3
Thanks for the replies and info.
John
Old Jan 26, 2005 | 10:40 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Keep in mind too that the max rating of the whole hitch system is only as high as it's weakest link. Putting a 15,000 lb Class 5 hitch on the truck and then using a ball rated for 6,000 lbs means the max rating is... 6,000 lbs, but you already knew that .
Gman22Expy
All Things Towing
20
May 24, 2022 03:47 PM
mssabo
1983 - 2012 Ranger & B-Series
Sep 5, 2013 01:24 PM
Chris89lx
All Things Towing
18
Mar 27, 2009 04:12 PM
ULTRATEC
Sep 19, 2005 04:44 AM
marginal
All Things Towing
Jul 17, 2004 08:38 PM
