Tachometer wiring
Old Jan 23, 2002 | 10:01 PM
jeandras's Avatar
jeandras
Post Tachometer wiring
I got this 79 ford bronco and the tach was all wired up except for the power wire. Where is a good place to put this wire where i wont blow or burn a fuse.
joseph
Old Jan 24, 2002 | 12:17 AM
sparky's Avatar
sparky
Tachometer wiring
You can always run it off the turn signals fuse,then the tach wouldnt have power unless the truck was running or at least the key in the run position. Or some other fuse that is only powered when the truck is running, like reverse lights, windshield wipers etc etc.
The power is for the light in the tach isnt it? Hey where does the Factory tach hookup???? Mil1ion are you out there?
Sparky
Old Jan 24, 2002 | 12:29 AM
Mil1ion's Avatar
Mil1ion
Tachometer wiring
Factory tachs are cable driven,and only have a light bulb in the back of it.
An aftermarket Tach to power it up,I would attach it to the radio wiring.
Or find an empty fuse position that's on the key.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=144&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=143&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 25, 2002 | 10:40 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Tachometer wiring
On my 78 Bronco, I spliced into the power wire for the heating control lighting. That way, the tach light is only on at night when the lights are on. BTW, the 78-79's did not have factory installed tachs available. :-)
Old Jan 25, 2002 | 11:04 AM
Mil1ion's Avatar
Mil1ion
Tachometer wiring
In his post it mentions POWER wire
NOT the Tach Illumination wire.
The POWER wire would have to be hooked up to a keyed power supply so it would work when the engine is running not when the lights are on.
The Tach Illumination wire would be attached to the Cluster lighting circuit.
Dennis
Old Jan 26, 2002 | 12:54 PM
Cowboy_351's Avatar
Cowboy_351
Tachometer wiring
I hooked mine up to the fuse that my radio is on and blew it so i switched it over to another fuse that only comes on with the ingintion in the Run or all the way to the left. seems to work fine.
Old Jan 29, 2002 | 12:30 AM
jeandras's Avatar
jeandras
i hooked up the power wire not the illumination wire to a power source where the radio and cb ran but the meter never moved. is there something else.
joseph
Old Jan 29, 2002 | 12:48 AM
Mil1ion's Avatar
Mil1ion
Tachometer wiring
[updated:LAST EDITED ON 29-Jan-02 AT 01:51 AM (EST)]Is the tach wire running to the - side of the coil?
Tach wires include:
Power
Ground
Tach/coil
Light
How many wires do you have?
Have a look here!
http://www.springfieldstreetrods.com/newimag/VDO_DIAGRAM_D.jpg
Dennis
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Jan 29, 2002 | 12:00 PM
Franklin2's Avatar
Franklin2
Tachometer wiring
KPFlyz
Nov 17, 2016 07:47 AM
jstsumgi
Sep 14, 2015 08:57 AM
Bootzz711
16
May 3, 2012 10:08 AM
Hunt89
Jan 1, 2010 05:22 PM
rodbender
Jan 26, 2005 07:40 PM
