Sponsored by: Real Truck
V10 and towing
Old Aug 15, 2008 | 09:55 PM
jmpopp's Avatar
jmpopp
V10 and towing
Will a V10 get the job done towing a 38' toyhauler? Had a diesel and sold it. Still have the trailer and can get a V10 real cheap. I only tow about 2 days a month. Let me know. Thanks
Old Aug 15, 2008 | 09:58 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE. You're liable to get quite a range of answers to that question.
Old Aug 15, 2008 | 10:02 PM
jmpopp's Avatar
jmpopp
Thank You,
What is your answer?
Old Aug 15, 2008 | 10:10 PM
SteveBricks
FTE Emeritus
What kind of truck? F250, F350?
If it's rated to pull the weight of that particular trailer, and won't exceed the GCVWR, then yes, it'll tow it.
Old Aug 15, 2008 | 10:20 PM
dsl_pwrd_ford's Avatar
dsl_pwrd_ford
buy a diesel
Old Aug 15, 2008 | 11:19 PM
QwkTrip's Avatar
QwkTrip
2 days a month? Go with the cheap truck whether V10 or diesel.
Old Aug 15, 2008 | 11:25 PM
biz4two's Avatar
biz4two
Arrow
Need the configuration of the V10 SD...
ie: Year, gear ratio, Auto or manual, 4x4 or 4x2, CC or Regular Cab or SuperCab, tire size, mileage, etc.
The YEAR and GEARS are the most important really.
biz
Old Aug 15, 2008 | 11:37 PM
cartmanea's Avatar
cartmanea
It should handle it fine, that trailer probably won't get too heavy. Just keep in mind, you can run the V10 all day long in the power band over 4000 rpms, don't try to drive it like a diesel.
Old Aug 15, 2008 | 11:51 PM
Monster-4's Avatar
Monster-4
Originally Posted by dsl_pwrd_ford
buy a diesel
And your reason(s) being?
Anyway like biz4two said year and gear makes a difference.
The 1999 was the lowest powered V10 in the F-series trucks. In 2000 Ford introduced the "PI" heads and bumped up the HP and TQ. In 2005 they introduced the 3V(alve) engine and again HP and TQ went up.
Coming from a diesel you'll have to get use to the V10 running at higher RPMs while under load. This is normal for the engine and it's designed to handel this.
What gears does the truck have? Many V10 owners seem to think 4.30 gearing is the sweet spot for a stock truck.
Old Aug 16, 2008 | 12:12 AM
Monster-4's Avatar
Monster-4
And welcome to FTE jmpopp!
Old Aug 16, 2008 | 12:28 AM
jmpopp's Avatar
jmpopp
It's a 2005 super duty 4x4 crew cab with 26k miles. Don't know what the gear ratio is yet. Immaculate truck for 15K.
Old Aug 16, 2008 | 12:36 AM
Kep4's Avatar
Kep4
Jäger
It's got the TorqShift transmission and if it's got 4.10 or 4.30 gears then you'll probably be just fine towing. If it's a 5th wheel TH just be careful of too much pin weight.
Have you weighed the TH yet?
Old Aug 16, 2008 | 01:29 AM
RDR's Avatar
RDR
Thumbs up
~ in a word "yes" ...
Old Aug 16, 2008 | 06:28 AM
Monster-4's Avatar
Monster-4
That sounds like a good deal.
Old Aug 16, 2008 | 06:56 AM
philipsc1's Avatar
philipsc1
Wow! Sounds like a deal that cant be passed up! If your towing only a couple times a month I think it'll be fine!
