Fitting panels
Old Aug 13, 2008 | 06:12 PM
funone46's Avatar
funone46
Fitting panels
Ok all you experts and tips on fitting the front fenders, doors and securing the cab?
Dave
Old Aug 13, 2008 | 08:04 PM
havi's Avatar
havi
I'll have the Roast Duck
a good eyeball, and patience.
Old Aug 13, 2008 | 08:09 PM
ssj7kids's Avatar
ssj7kids
I'm pretty sure that there is a really good step by step description on here somewhere. Did you try search? I'm on vacation in NH so I don't have my stuff, but I'm pretty sure I printed something off of here. Perhaps from Ax????? I remember it talked about starting with the hood, and then the fenders....
Old Aug 13, 2008 | 08:14 PM
funone46's Avatar
funone46
I was not able to find anything. I am looking a getting a body book from one of the vendors
Old Aug 13, 2008 | 08:40 PM
dylan1952's Avatar
dylan1952
TIME AND PATIENCE!!! Here is AXRacers post on alignment of front groups. I believe it is one of the best articles you will find.
My suggestion: Most try to align the rest, then do the hood. As stated above the hood is aligned first then the rest of the front clip is aligned to it. First I will assume the frame to cab mounts are in good condition with good rubber and cab mounted straight. You'll never get the front right if the cab is crooked. Start with the radiator support horseshoe with all the front sheetmetal off the truck. Make sure the rubber isolator under it is in good shape, not hard/cracked/missing, the bolts are free. Put the truck front end on jackstands under front of frame, level front to back on frame and side to side on cowl seam. CAREFULLY adjust the horseshoe until the top is level, the distance from the front support rod mounts on the firewall to the top corner of the horseshoe is equal side to side. Add the wind deflectors to the sides of the radiator support, only snugging the bolts. remove the hood latch plate from the latchplate strip and mount the strip to horseshoe and deflectors. Adjust the deflectors as needed until the strip is also level and square to cowl, tightening the bolts in several steps like tightening a head on an engine. Set the hood in place without hinges, verify that you can get the hood to match up to the cowl with an even gap (hood gap will be larger than the 1/4" we usually try for when aligning sheetmetal, just the nature of the beast, you did replace the cowl windlacing didn't you?) Try placing temporary 1/4" spacers between the hood edges and the front hood latch strip to simulate the front rubber hood bumpers. If the hood won't align, you need to find out why before proceeding, likely the cab mounts need adjusting. If the front of the hood is decidedly off center the cab isn't square to the frame.
Once you have the hood sitting properly and evenly gapped around the cowl, remove it and add the rest of the front sheet metal, tightening all the bolts just finger tight. add the front end support rods with the adjusters just touching the front brackets. Make sure you have all the hood to fender bumpers in place and they are not hard or damaged.
Now set the hood back in place as before. This will likely take two people, but align the rear of each fender with the edge of the hood and the front even with the front of the hood. Don't worry if they droop a bit in the front. Snug all the bolts between the fender and cowl, inner fender, and lower valance pan, leaving the fender to wind deflectors and lower brace just finger tight. Repeat on other side. Now adjust the support rods to bring the front of the fenders up to align with hood. Additional tightening will bring the center of the fender to hood alignment up and the front edge of the fender back, tighten until you are satisfied with the fender to hood fit, then tighten the deflector to fender bolts and the fender support strut. Hopefully all of this has put the frame horns centered in the cutouts in the lower pan. If not you can adjust some by bending the support struts to move the bottom of the fenders side to side.
Finally you are ready to hinge the hood! First look in my "misc gallery" for the hinge pictures, remove the springs and be sure the hidden hinge pivot shown is not frozen and working freely. Even new hinges can have this pivot tight or paint frozen, and if tight the hood will never close properly! Bolt the hinges to the cowl just snug enough to support the hood, and bolt the hinges to the hood with the proper shoulder bolts and wavy washers, tighten the shoulder bolts just slightly more than finger tight, NO TIGHTER! Now carefully close the hood. Adjust the hood hinge to cowl location until the hood closes without excessive drag on windlace or contact with cowl or fenders. The hood should set down in the same alignment as before hinges were attached. Once the hood is opening and closing smoothly tight hinge mount bolts, and add a safety wire thru the heads of the shoulder bolts so they cannot loosen. Finally add the lower latch mechanism to the latch plate panel. Adjust the latch plate until the hood latches smoothly and sits properly. If the rear of the hood doesn't pull down by itself (and that pesky pivot is free), adjust the latch plate further forwards to pull the hood forwards as it latches, that should get the rear of the hood to come down.
Take your time to get each step exactly right before going on and everything should align and work better than when it came out of the factory!
Old Aug 13, 2008 | 08:46 PM
havi's Avatar
havi
yes, it is one of the best, IMO, also. These old trucks are a bit different than, say, 1967 and newer.
Old Aug 13, 2008 | 11:01 PM
4tl8ford's Avatar
4tl8ford
Remember the whole front assemble was designed to twist and shift with the roads, fields, etc.
As designed you should be able to stand at a front cornor and move the fender about 1 - 1.5 inches up and down.
Old Aug 14, 2008 | 05:56 AM
funone46's Avatar
funone46
I just have to remember it is not up todays standards. From some of the trucks in PF, just get it close. I guess you tape the rubbber in place rather than glue them at this time
Thanks
GocartMozart
Jan 10, 2016 08:17 AM
1989lariat
Dec 30, 2014 02:56 PM
BamaDave
2004 - 2008 F150
Nov 15, 2013 04:59 PM
bleedford
Jun 20, 2012 07:08 PM
wbhinton
16
Sep 5, 2006 11:21 PM
