PCM or E4OD
Old Aug 11, 2008 | 10:33 AM
Fordy1's Avatar
Fordy1
PCM or E4OD
Trans went into limp mode (blinking OD light) while towing 6,000 lb trailer, had the code read and, 0603 Check KAPWR To PCM, was the only stored code. I have been fighting this for over a year now and can't figure which way to turn. Trans is rebuilt, ATS TC, The Cure, and Tru-Cool Max and it still happens, but only while towing. I can reset it by pulling the #9 Max fuse and all works good for another 20 miles. I tow in OD except hills, it seems to happen as the trans shift between 3 and OD, even on slight grades like an overpass, I do not let it hunt. While in limp mode the truck dies in reverse, cant back the trailer, TC is locked, until I pull the fuse. What up?
Old Aug 11, 2008 | 11:18 AM
MADVAN's Avatar
MADVAN
What scanner was used?
Some will not pickup trans codes.
Under those conditions most times its a slip code.
Really need to get the codes out.
The kam error could come from a chip/downloader.
Could be a leak in the TC lockup piston. The higher
line pressure in limp and R could lock the TC.
Just a wag.
Bill
Old Aug 11, 2008 | 03:23 PM
Fordy1's Avatar
Fordy1
What type of scanner do I look for, the one used was at the shop I do all my buisness with, I told them that I was looking for the trans codes and 0603 was what I got back, no other code in there. I was also told that a bad PCM could be the cause for the limp mode.
Old Aug 12, 2008 | 05:12 PM
Fordy1's Avatar
Fordy1
Anyone? Buler?
Had to give it one more shot, please forgive the repost
Old Aug 12, 2008 | 06:42 PM
tjbeggs's Avatar
tjbeggs
Bill is right on as usual. Try a different scanner.
Old Aug 12, 2008 | 09:46 PM
c00nhunterjoe's Avatar
c00nhunterjoe
if it always happens on the 3-4 shift its probably a tc slipping, but as bill said, you need a different scan tool. if it goes to limp mode then there is a code stored
Old Aug 13, 2008 | 07:03 AM
MADVAN's Avatar
MADVAN
When you pull the fuse/fuses you could be removing the stored code/codes.
Do not reset the pcm and have it scanned.
Bill
Old Aug 13, 2008 | 09:09 AM
Fordy1's Avatar
Fordy1
I had it scanned while still in limp mode, I pulled the fuse after the 0603 code was found. Looks like I will have to take the trailer for another tow and have the codes read at a different shop. Thanks for the input, as always it's apreciated.
Old Aug 13, 2008 | 10:23 AM
MADVAN's Avatar
MADVAN
What year is your truck? OBD1?
Bill
Old Aug 13, 2008 | 04:00 PM
Fordy1's Avatar
Fordy1
1996, The Cure, Tru-Cool Max, soon to be HPX and 203*. Could a shift kit help this situation?
Old Aug 13, 2008 | 05:09 PM
MADVAN's Avatar
MADVAN
You should be OBD2.
We need to get the codes out before you do anything.
The OD lamp flashes and you get limp mode so we know its in failure.
Its possible that You lost the kam signal.
In 96 the kam line has a splice in it. (S#126)
Need to remove the connector off of the PCM and test Pin #55.
Its ckt#37 and is a yellow wire. Its 12v 24hr.
I have to go and look up the ground that carries the kam.
Dont have it off hand.
Do this if you are shure that the scan used was good.
If you have power and the grounds it could be the PCM.
Rick or Cuda might be able to post the diagram i cannot.
Bill
Old Aug 13, 2008 | 05:36 PM
Action4478's Avatar
Action4478
Ask & ye shall receive...
PCM pinout ....
Old Aug 13, 2008 | 05:55 PM
MADVAN's Avatar
MADVAN
Rick
Excellent!!!
But need the pinout chart also.
Chart shows what the ckt/pin #'s are for.
Pulling fuse 9 tells me Pin 55 should be hot.
Need to check the grounds.
Worth a shot before changing the PCM
Bill
Old Aug 13, 2008 | 06:21 PM
Fordy1's Avatar
Fordy1
Thank for the info Action and Mad. So there is a ground associated with pin 55 that I need to identify and then test the pin to ground and should read 12v? or is testing the ground a different procedure? What is ckt 37?
Old Aug 13, 2008 | 06:23 PM
Hussler's Avatar
Hussler
Courtesy of Tjbeggs ... Transmission - PCM wiring interface.
<a href="http://good-times.webshots.com/photo/2420581080099659029jiCatA"><img src="http://thumb9.webshots.net/t/60/660/5/81/8/2420581080099659029jiCatA_th.jpg" alt="Transmission"></a>
