Pin 55 is hot (+).
Pin 25,51,76,77 and 103 are grounds (-).
Just test from pin 55 to each of the pin grounds.
Click on Ricks photo. You will see Pin #55.
Its ckt #37, wire color yellow.
If test is good its an internal failure. (pcm)
Need to fix this first, then the trans issue.
