over heating
Old Aug 10, 2008 | 11:32 PM
83maverickf-100's Avatar
83maverickf-100
over heating
my 83 f-100 is runnin between half (m in normal) to 3/4 (a or L in normall) insted of on the n or o like it used to. i used a hand held heat gauge it said the rad was at 125 degrees one side and 170 on the other new fluid and temp gauge still the same it scares me but seems to run great imao not the head gasket thats for sure any ideas?
Old Aug 11, 2008 | 05:19 AM
Motorhead351's Avatar
Motorhead351
change/check the thermostat?
Old Aug 11, 2008 | 12:23 PM
fmc400's Avatar
fmc400
MSEE
You need to install an aftermarket mechanical gauge. The factory gauge is more of a go\no-go deal and it can't be used to diagnose overheating problems because it's too subjective. "Close to the L" is not a scientific measurement.
Also, an IR gun can't be used to diagnose overheating problems either. They read the surface temperature of the target, not the internal temperature. The temperature of the radiator, or even the coolant in the radiator, is not the temperature of the coolant circulating in the engine block.
I will say it again - you cannot characterize your overheating issues with the tools you are using. A mechanical gauge that threads into the block is your only option.
Old Aug 15, 2008 | 05:09 PM
jesterdog's Avatar
jesterdog
Does it cool off on the highway?
RileyCarroll
31
Nov 27, 2016 01:36 PM
BGF100
Nov 13, 2015 08:14 PM
bcamill
Oct 1, 2015 04:48 PM
Truck55
34
Sep 11, 2010 06:08 PM
Sudsrat
1997 - 2003 F150
Oct 23, 2009 09:55 PM
