Thermostat?
Old Nov 24, 2016 | 06:18 PM
RileyCarroll's Avatar
RileyCarroll
Thermostat?
I have a 1973 f-100 with a 302 and factory air (I think). I recently installed a new radiator because the older one was leaking. It now seems to run a lot cooler but it never gets to operating temperature. It used to go about 5/8-3/4 of the way up the gauge with the old radiator, but still stayed well within normal range. Now the needle barely moves. At first I just thought my gauge was inaccurate, but now it's getting colder and my heat isn't really working that well, so I'm thinking thermostat. What do you guys think?
Old Nov 24, 2016 | 08:02 PM
redcreekauto's Avatar
redcreekauto
Yes thermostat. As cheap as they are anytime you open the cooling system that much its cheap insurance to change it out IMO
Old Nov 24, 2016 | 08:09 PM
Tedster9's Avatar
Tedster9
A lot of guys these days are saying the generic replacement stats are no good at all and recommend Motorcraft only.
Old Nov 24, 2016 | 10:17 PM
meangreen92's Avatar
meangreen92
And just as with all new parts manufactured during this century, test it first, like in a pot of boiling water. Plenty of defective thermostat stories out there these days...
If you can't get to it as soon as you'd like, you can always stick some cardboard in front of part of the radiator, to bring the temps up a little.
Old Nov 24, 2016 | 10:24 PM
RileyCarroll
Thanks everyone for the help, I plan on replacing it tomorrow, I guess I can get a genuine motorcraft at any ford dealer, right?
Old Nov 24, 2016 | 10:46 PM
redcreekauto
Yes you can pick one up there. But I also recommend Mr Gasket brand. I've yet to have one become defective.
Old Nov 24, 2016 | 11:08 PM
RileyCarroll
thanks, I'm not sure which one I'll go with, i was originally going to get the $3 they will sell me at o'reilly but I'll probably go with motorcraft now, or Mr. gasket, depending on which way I feel like driving tomorrow
Old Nov 25, 2016 | 02:17 AM
Ozzie H.'s Avatar
Ozzie H.
You'll probably find what you want, but if not, here's another source with many choices:
1973 FORD F-100 5.0L 302cid V8 Thermostat | RockAuto
Be sure to get a replacement gasket also, and put a bit of goop on it after thoroughly cleaning and checking the mating surfaces. Some anti-seize on the bolts' threads will help some on the next removal.
The advice about testing it in a pot of water with a known good thermometer is good advice. Sometimes even a new part doesn't perform as it should. The original in my '76 was rated at 178F.
Old Nov 25, 2016 | 09:18 AM
RileyCarroll
1973 FORD F-100 5.0L 302cid V8 Thermostat RockAuto
Those prices are much better than what I'm going to pay today at o'reilly, but I won't have time to do it for a while if I don't do it today. Good idea on the anti-seize. I dead this because my radiator doesn't have a drain plug
Old Nov 25, 2016 | 10:56 AM
Ozzie H.'s Avatar
Ozzie H.
Drain plugs can be added to the lower tank or in-line on the lower hose. In it's absence you'll probably just have to release the lower hose clamp. It's messier, but it will get it done.
Old Nov 25, 2016 | 11:17 AM
RileyCarroll
I've hit a snag, I can't get to the bottom bolt, can I remove the vacuum advance canister off of the dizzy to access the bolt? Or will this cause problems
Old Nov 25, 2016 | 12:40 PM
RileyCarroll
Ended up taking it off, the thermostat was shut, not frozen open like I thought it would be. Hope it's the problem and not something else
Old Nov 25, 2016 | 12:45 PM
meangreen92
The "open" temperature should be stamped/engraved on the T'stat, on the wide round part of it. Maybe someone put a 160º 'stat in there.
Old Nov 25, 2016 | 03:49 PM
RileyCarroll
it looked like it was stock, only number I could find was 192. I got the other one in. When I was installing it my wrench slipped and I busted two ports of the ported vacuum switch. So that won't be fixed until Wednesday when the part comes in. If it's not the thermostat, what else could it be?
Old Nov 25, 2016 | 03:54 PM
meangreen92
Could be the blend door inside the heater box.
