AOD Trans question
Old Oct 1, 2015 | 09:43 AM
bcamill's Avatar
bcamill
AOD Trans question
I have an 83 F100 flareside with a 302 and AOD trans. The trans has been freshly rebuilt . In the morning when all is cold, it shifts great. Once it warms up in a mile or two, it shifts from 1st to second harder than normal. All other gears shift as desired. When coming to a stop it shifts down as normal for all gear including second. I have used the correct fluid and all else seems great. Any thoughts? Is there an additive I should use?
Old Oct 1, 2015 | 12:26 PM
Franklin2's Avatar
Franklin2
Was this trans swapped in or is it original? What type of throttle control does the trans have, a cable or a metal rod?
Who rebuilt the tranny? You could certainly take it back to them? Sounds like it could be a minor adjustment on the throttle linkage. You could certainly burn it up if it's adjusted wrong.
Old Oct 1, 2015 | 12:32 PM
bcamill's Avatar
bcamill
It was a swap. The company was out of Florida and I am in the southwest, so expensive to return. It does have the kickdown rod and I have adjusted it properly. I can give that one more look, but when we installed it was within tolerance at .4 inches and less than 5psi at idle.
Old Oct 1, 2015 | 04:48 PM
Franklin2's Avatar
Franklin2
Yes, and the more I think about it, you would think the rod being out of adjustment would affect all shifts. I would call them anyway and see what they say.
4x4-jacked-up-93
Jan 14, 2011 12:19 PM
Supercab
Apr 25, 2009 07:16 PM
bfbiker
Dec 8, 2008 11:39 AM
aka rotten
Mar 17, 2007 07:44 PM
flatheadjim
Mar 31, 2004 04:56 PM
