Injectors
Old Aug 8, 2008 | 07:32 PM
sassydog's Avatar
sassydog
Injectors
CAN SOME ONE TELL HOW TO FIGURIE OUT WHICH INJECTOR IS NOT WOR WORKING. DOSE IT COME UP IN CODE . 95 7.3 FORD DIESEL. CAN USE SOME INPUT.
Old Aug 8, 2008 | 07:40 PM
Action4478's Avatar
Action4478
You need a scanner that can do a contribution test .....
Are you getting a CEL?....
Old Aug 9, 2008 | 05:41 AM
sassydog's Avatar
sassydog
actioh4478 not sure what you mean by cel
Old Aug 9, 2008 | 06:31 AM
FARM69's Avatar
FARM69
CEL = check engine light
Old Aug 9, 2008 | 09:58 AM
MagKarl's Avatar
MagKarl
Remove your valve covers and unplug each injector one by one, the one(s) that don't make much difference when unplugged are the place to start.
Old Aug 9, 2008 | 04:55 PM
glasseater's Avatar
glasseater
can't you leave the valve covers on and unplug a harness that goes to 2 injectors each to narrow it down to which bank/2 cylinders??? or was this all in a dream?
Old Aug 9, 2008 | 08:18 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Some times that works some times not. But it is always worth a try before you pull both valve covers.
Old Aug 9, 2008 | 09:13 PM
dieselguy2008's Avatar
dieselguy2008
If you have a laser thermometer u can use it. Take the temps off each exhaust port on the manifold. They should be close to the same on each. Just some advice.....if they are electronic injectors........they can knock the snot out of you with the electricity goin thru them. I tried that on an N-14 Cummins one time, that was the only and last time I try that. I'll take exhaust readings if no laptop is available
RacinNdrummin
30
Apr 17, 2013 08:44 AM
79sparky
Jan 14, 2013 04:39 PM
rLmcowboy
Sep 17, 2012 09:48 AM
lhud
25
Sep 8, 2011 09:31 PM
Jrock909
Oct 31, 2004 10:02 PM
