fuel injectors are leaking
Old Jan 14, 2013 | 04:12 PM
79sparky's Avatar
79sparky
Some of my fuel injectors are leaking. Does this mean new injectors, or is there o-rings I can replace?
Old Jan 14, 2013 | 04:22 PM
airdale94's Avatar
airdale94
It depends on where they're leaking. The T fittings for the return lines have O rings. Also the return lines can leak. If they're leaking into the cylinder then it could be time for new ones.
Old Jan 14, 2013 | 04:23 PM
whiteboyslo's Avatar
whiteboyslo
Sounds like the o-rings for the return lines are shot. Common problem and easy to fix. Do a search for 'return line' and you'll get all the info you need.
Mike
Old Jan 14, 2013 | 04:39 PM
79sparky's Avatar
79sparky
Ok thanks that's about 300 bucks cheeper ill give that a shot, two of the return lines are leaking. Thanks again guys I really appreciate it.
pawayne63
Nov 8, 2016 07:31 PM
Benny D
Nov 30, 2010 06:16 PM
fisheasy
Mar 6, 2009 02:24 PM
knash0727
Apr 24, 2008 08:27 PM
chipper
Oct 20, 2006 02:03 PM
