1978 - 1996 Big Bronco
1990 Bronco 5.8l e40d trans
Old Jun 10, 2000 | 12:01 PM
sharlo's Avatar
sharlo
Can anyone tell me the proper way to check the tps?
I am levaing ignition off,connecting a tester to both connectors . Then move the throttle.
When I connect tester to both it show continuity.
I checked voltage and ohms, but not sure what to look for
Is there something wrong here?
Thanks in advance
Old Jun 10, 2000 | 12:41 PM
cw300mag's Avatar
cw300mag
TPS throttle position sensor
if this sensor is bad the results will be fast idle like the throttle has a mind of its own
my 93 f150 w/ 302 tps whent bad and it idled at about 2ooo rpms it was hell when i had to put it in gear .as fare as testing it i am not sure.
athough i would just replace it they are under 50 bucks
cw300mag(No Email Addresses In Posts!)
Old Jun 10, 2000 | 06:32 PM
n5mj's Avatar
n5mj
To check the TPS, you'll need to find the 3 wires coming out of the sensor. Two choices -
1. check the voltage with the harness connected and the key on, should vary smoothly from around 1V to 5V as the throttle is moved from idle to WOT. If 5V always, move a lead to the other wire. If the voltage is negative, that's okay, just the voltmeter leads are backwards, no problem. Any jumping around of the reading, particularly just off idle or at idle, the TPS needs to be replaced.
2. check resistance with the harness disconnected. The TPS will read around 4Kohms top to bottom. Checking from the wiper to one side, the resistance should vary from around 800 ohms to full value from idle to WOT. Again, the reading should smoothly increase (or decrease, as the case may be)
The TPS is a potentiometer that nearly always wears at the just-off-idle point. It gets erratic, the CPU interprets that erratic TPS voltage as throttle movement, and the motor stumbles or skips.
I've had to replace the TPS at 100,000 miles or 7 years (more or less) on most every EEC Ford I've ever owned.
Good luck
Mike
Old Jun 10, 2000 | 07:05 PM
sharlo's Avatar
sharlo
Thanks alot Mike for the info. I am not sure how I could test with the wires on? Any ideas?
Old Jun 12, 2000 | 09:06 AM
garymac's Avatar
garymac
Colorado Horseman
Jan 5, 2017 07:25 PM
bl2009
3.8 & 4.2L V6
Dec 9, 2016 11:03 PM
Hank85713
Modular V10 (6.8l)
Oct 12, 2015 06:04 AM
al0311
Aug 11, 2015 02:23 PM
jwcorder
1983 - 2012 Ranger & B-Series
Apr 26, 2006 05:41 PM
