Sponsored by: Auxito
Loosing digital odometer reading
Old Aug 6, 2008 | 12:24 PM
jmegs's Avatar
jmegs
My 2000 F150 has been loosing the digital odometer reading it comes on and sometimes goes out for a time, is it an easy fix, or what do I need to buy to fix or replace it.
Old Aug 6, 2008 | 04:21 PM
irishammer's Avatar
irishammer
You will get faster results in the corect forum...this is for 2009 F150's...
Old Aug 6, 2008 | 05:28 PM
LxMan1's Avatar
LxMan1
It is a bad solder joint. Easy fix.
Old Aug 6, 2008 | 07:24 PM
vanman250's Avatar
vanman250
If you do a search you'll find instructions on how to repair it. Mine does the something but I just ignore it since I'm to lazy to do the repair.
vanman250
Old Aug 7, 2008 | 08:02 AM
KingRanchMan02's Avatar
KingRanchMan02
Here it is! Good luck!
https://www.ford-trucks.com/forums/196821-odometer-blackout-problem-fixed.html
Old Aug 7, 2008 | 09:48 AM
ground_zero298's Avatar
ground_zero298
I soldered mine, easy to do, worked fine after that, I couldn't see the broken joint so I heated them all, just make sure you don't have the solder bleed over to another contact, if you do try dragging the solder tip inbetween the posts, if that don't work use a small screw driver to remove it.
bbsitum
1997 - 2003 F150
Jul 15, 2013 09:04 PM
erh1960
1997 - 2003 F150
Mar 2, 2011 03:52 PM
va150
Oct 15, 2008 05:30 PM
SarERob
Electrical Systems/Wiring
Jul 16, 2008 05:08 PM
minnesota4x4
Feb 28, 2006 03:56 PM
