VIN Decode Please
Old Aug 5, 2008 | 09:37 AM
BroncoSK's Avatar
BroncoSK
VIN Decode Please
69910280L-211162A
Trim-03
Paint-TT
Engine/ Trans-SP 3L/D
I can't tell if it has a 240 or a 300 cu/inch. Its a 1965 F-100. Any help on the history would be appreciated.
Old Aug 5, 2008 | 10:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BroncoSK
69910280L-211162A
Trim-03 = Medium Green Crush Vinyl & Medium Green Wicker Pattern Vinyl / 81A Standard Cab
Paint-TT = Dynasty Green (Canadian only colour).
Engine SP = 240 1V I-6
Trans: 3L/D Ford Type 3.03 3 Speed Manual all Syncromesh Transmission
I can't tell if it has a 240 (is) or a 300 (is not) cu/inch. Its a 1965 F-100. Any help on the history would be appreciated.
Welcome to FTE
Canadian only VIN: 69910280L-211162A
6 = 6 Cylinder Engine
99 = Styleside Pickup
10 = 100 Series
28 = 128.8" Wheelbase
0 = ? You sure there's an 0 here? According to the parts catalog Canadian VIN decode chart, there are only 8 digits in the first part of the VIN number. The 0 doesn't belong, because that makes 9 digits.
L = Left Hand Drive
211162 = Numerical Sequence of Assembly = Oakville, Ontario Canada Assembly Plant = 1965
A = Weight Range = From 3600 to 5600 lbs. Gross Vehicle Weight Rating
Info source: 1964/72 Ford Truck Parts Catalog
Old Aug 5, 2008 | 10:23 AM
BroncoSK's Avatar
BroncoSK
Thank u so much.
Luke79
1978 - 1996 Big Bronco
Jun 14, 2012 10:07 PM
RedLang
Jan 13, 2012 11:11 AM
Neil
1997 - 2003 F150
May 23, 2007 10:25 PM
dldagneau
Aerostar
Mar 6, 2007 05:14 AM
