1978 - 1996 Big Bronco
Transmissions
Old Jun 14, 2012 | 01:56 AM
Luke79's Avatar
Luke79
Transmissions
Will a 5.0L transmission work on a 5.8L?
Old Jun 14, 2012 | 02:16 AM
greystreak92's Avatar
greystreak92
In most cases, yes. Which transmission are you dealing with?
Old Jun 14, 2012 | 02:23 AM
Luke79's Avatar
Luke79
Well I'm looking to buy a bronco for 600 and it needs a transmission..and I haven't found a 5.8 transmission
Luke79's Avatar
Luke79
The bronco has the 5.8 in it^^
Old Jun 14, 2012 | 02:30 AM
greystreak92
What year Bronco? Automatic or manual?
Old Jun 14, 2012 | 02:41 AM
Luke79's Avatar
Luke79
It's a 94 and automatic
Old Jun 14, 2012 | 02:55 AM
greystreak92
With a 94 you are looking at an E4OD to put into it. An E4OD from any 4WD (this is important because there are 2WD units out there and they will not have the correct tailhousing) F-Series or Bronco with a 4.9L (300), 5.0L (302) or 5.8L (351) will work. You do NOT want an E4OD any older than 94 model year though unless you have documentation that it has been rebuilt. And even then, don't even sniff at an E4OD from 1990. I will warn you, the E4OD is not small nor is it an inexpensive piece of machinery. Rebuilt units can tip the scales at $2600-$3000. Used units are ok, but watch high-mileage units and beware any unit that shows discoloration in the fluid (darkened or brown).
Old Jun 14, 2012 | 04:51 AM
b4hntn's Avatar
b4hntn
To be on the safe side I would choose only the 95-96. The original owner told me the transmission was rebuilt under warranty recall on my 94. You might get that information from Ford for the one you are looking at.
The transmission may not be the culprit. It could be electrical like corroded connectors, VSS, MLPS, PCM or transmission solenoid pack. Like greystreak92 said look at the fluid color and smell it. Drop the pan and look for metal debris before replacing it. The solenoid pack and 14 qts of fluid would be the most expensive. If you DIY, about $400.
Old Jun 14, 2012 | 10:07 PM
GruesomeJeans's Avatar
GruesomeJeans
I think he said that the bronco he was looking at buying didn't have a trans in it... He is looking for one to pop in there.
SDElwood
1966 - 1977 Early Broncos
Jul 4, 2015 12:43 PM
oorah2012
Oct 19, 2012 09:38 AM
Ryan87lx
Oct 28, 2006 01:52 PM
Marsa
May 12, 2004 05:55 PM
David
Nov 25, 1999 10:34 AM
