stealership?
Old Aug 4, 2008 | 03:20 PM
tndiesel's Avatar
tndiesel
stealership?
Just thought I'd call and see what the stealership would charge to change the tranny/differential fluid. $210 for the tranny fluid and either $190 for limited slip or $140 for other differential. I can't remember how I know whether I've got a limited slip or not. Is it in a code somewhere?
Old Aug 4, 2008 | 03:39 PM
NWBronco's Avatar
NWBronco
If the diff tag is still there. There will be an 'L' in the mix. Usually in between the axle ratio numbers.
Bob
Old Aug 4, 2008 | 03:44 PM
tndiesel's Avatar
tndiesel
Bob
Is the tag on the outside?
Old Aug 4, 2008 | 03:50 PM
NWBronco's Avatar
NWBronco
Yep, it's on one of the diff cover bolts.
Old Aug 4, 2008 | 05:36 PM
c00nhunterjoe's Avatar
c00nhunterjoe
good god, i would hope you arnt considering it....
Old Aug 4, 2008 | 05:53 PM
secondarychaos's Avatar
secondarychaos
that's exactly what i thought. for a whole 20$-30$ in fluids and half an hour...
Old Aug 4, 2008 | 05:54 PM
c00nhunterjoe
maybee 35 if yu let the converter drain really good. lol
Old Aug 4, 2008 | 06:03 PM
tndiesel's Avatar
tndiesel
I agree, God is good! No I'm not letting the stealership do it, just wanted to see how much of a rip off it would be. Can anyone tell from my differential tag what kind I have? I can't make out any L anywhere. Also, I'm going to buy tranny fluid, rear end fluid and a tranny filter. What type fluids and where can I get the tranny filter. Lastly, I need silicone for the rear end cover, what kind?
Thanks!
Old Aug 4, 2008 | 06:15 PM
NWBronco's Avatar
NWBronco
It's not a Limited Slip, so, you'll need to get the axle code from the data plate on the driver's door post.
Old Aug 4, 2008 | 06:19 PM
tndiesel's Avatar
tndiesel
The axle code is D5
Old Aug 4, 2008 | 06:22 PM
BlueMule's Avatar
BlueMule
Thanks!
This'll help you decode the tag on the diff.
Identifying Your Rear Differential
Old Aug 4, 2008 | 06:25 PM
BlueMule's Avatar
BlueMule
And this'll help with the fluid change in the tranny:
The TheDieselStop.Com 1999-up FAQ
BTW, it was written for a SouperDooty but the procedure is the same for an OBS.
Old Aug 5, 2008 | 12:57 PM
tndiesel's Avatar
tndiesel
I sure would like to know where int eht world you can get all the ATF/gear oil for $30. The gear oil alone was more than $30.
Old Aug 5, 2008 | 12:58 PM
tndiesel's Avatar
tndiesel
You said by looking at my axle tag it's not limited slip but accoirding to my axle code "D5" it is a 4.10 limited slip. How in the world do I know for sure?
Old Aug 5, 2008 | 01:54 PM
NWBronco's Avatar
NWBronco
The diff tag has no L on it. Your door tag says D5, an LS. I, personally have never trusted either. I open the diff, count the teeth on the ring gear and pinion gear, then I know what I'm running. I'd drop the diff cover, let it drain, and as it's draining, go get what I now know it needs.
The easiest way to tell is to drop the cover and look. If it's a open diff, you'll see the side and spider gears easy enough. An open carrier is just that, open to the side and spider gears, no positive drag applied at all. In a LS carrier, you'll either see an enclosed carrier, or steel/fiber disc plates on either side of the side gears. Side gears are on the 'sides of the carrier, and are what the axle shaft splines insert into. The spider gears are what the cross shaft inserts through. The spider gears are what walk around the carrier, leaving you with one tire not spinning while the drive wheel has no traction, spinning in the air.
Bob
