E4od stock shift question
Old Aug 4, 2008 | 09:06 PM
glasseater's Avatar
glasseater
Originally Posted by c00nhunterjoe
light/ normal throttle is almost always while in 3rd gear mid way through the gear range
yeah i wasn't really thinking about WOT, but now that you mentioned i remembered how bad that stock tuning was in the 2-3 shift at WOT... i can definitely see how manually shifting that would help a lot
Old Aug 4, 2008 | 09:14 PM
joe_13894's Avatar
joe_13894
Originally Posted by glasseater
i don't really remember how my truck ran stock but... with my custom tunes it will NEVER lock in 2nd gear... once it hit 3rd it would lock...
If you did any mountain driving with 15k to 25k gross combo weights, you'd wish it did. There is just WAY to much heat produced by an unlocked TC at full throttle for even the biggest cooler to take away - flow rate is limited by the pump, and that limits the amount of heat that can be taken away.
Old Aug 4, 2008 | 09:16 PM
c00nhunterjoe's Avatar
c00nhunterjoe
well then you just need some more horsepower and good tuners so you can pull the hills in 3rd then.....lol or just do the torque converter clutch mod.
Old Aug 5, 2008 | 06:31 AM
glasseater's Avatar
glasseater
hahaha true, i want to get some sort of tc lock-up switch for this thing, for towing not for racing
Old Aug 5, 2008 | 06:39 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Ok, I am feeling a little better about the trany.
When I am going between 30-40mph at a constant speed and give it some throttle the rpms will go up 300-500 rpms but not really accelerate the truck very much, is this normal torque converter slippage? I am used to standards anyways so it will take a little while to get used to the big automatics.
Other then that, it seems to act normal to me.
secondarychaos posted a link to a transmission modification kit toward the begging of the thread, is this something any of you guys have done and how involved is it?
Thanks for all the help, greatly appreciated.
Old Aug 5, 2008 | 07:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by wildstang
I have read that the diesel converters are different then the gas ones but on my 98 escort wagon I don't notice that type of action
Diesel and gas torque converters are different, but the theory of operation is identical. What's different is in the tuning and strength, but they all work the same way.
In the diesel the engine has enough torque that when the torque converter locks the truck accelerates AND the engine slows down. In an Escort, the car accelerates a tiny bit and the engine slows down. There's a lot less torque in the Escort engine.
Old Aug 5, 2008 | 04:43 PM
MADVAN's Avatar
MADVAN
E4OD= Electronic 4speed Overdrive.
The locking TC can feel like a gear change depending on
how the trans is setup (locking pressure), and how much
torque multiple it has. Locking the TC removes the multiple.
Bill
Old Aug 5, 2008 | 07:04 PM
c00nhunterjoe
i havnt had any experiance with the ese kit listed in the begining but all the feedback so far has been good. the majority of the springs you get are for the valve body, thats nothing new, almost every shift kit you buy replaces them as well. the big difference in that kit is the elimination of the electronic pressure control whic is the main issue with our fluid system in the trans
Old Aug 5, 2008 | 07:48 PM
MADVAN's Avatar
MADVAN
X2 c00n
Not to big of a deal if you run one tune.
Big deal if running a flip chip. (my opinion)
Trans is much more consistent with it.
Bill
Old Aug 5, 2008 | 08:13 PM
glasseater's Avatar
glasseater
yea that is completely normal, when the TC is unlocked it's supposed to do that
Old Aug 5, 2008 | 08:44 PM
c00nhunterjoe
i run one tune with mine and if i want to make the epc angry i can by simply "adjusting" throttle at different times... no different then if you were just driving along and hitting small hills or in minor traffic. the epc is annoying.
Old Aug 6, 2008 | 06:37 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
So to install the kit, do you take the pan off the bottom of the trany and is that where the whole kit goes?
Old Aug 6, 2008 | 09:38 PM
  #28
glasseater's Avatar
glasseater
if you're talking about doing a valve body?? you take out the stock one (first thing you see after you take off the transmission pan...) and you throw in the new one
Old Aug 6, 2008 | 09:45 PM
  #29
c00nhunterjoe
if you buy the ready to go valve body it will look like this.
and it goes here.
digitalsam
1983 - 2012 Ranger & B-Series
Apr 30, 2013 09:49 AM
Scifi266
Oct 2, 2012 10:32 PM
santan40
Jul 2, 2012 05:36 AM
Ford4Life7.3
18
Nov 10, 2011 09:31 AM
alabama madman
15
Jan 30, 2009 08:36 PM
