HEADLIGHTS FLICKER!
Old May 15, 2002 | 07:46 AM
fasch74's Avatar
fasch74
HEADLIGHTS FLICKER!
[updated:LAST EDITED ON 15-May-02 AT 09:30 AM (EST)]When Im driving at night my headlights flip on and off. They are not rhythmic and they have no ryhme or reason. The dash lights and everything else electrical have no problems and dont even dim. I had a cop tell me that he thought it was the bright light switch. I dont know if he is on top of things or not. What makes them flip on and off????
It is a 1965 F-100.
Old May 15, 2002 | 01:09 PM
sparky's Avatar
sparky
HEADLIGHTS FLICKER!
Well it could be the brite/dim switch. They get corroded and wear out, so it could very well be the problem. Also check the connections on the headlight switch, the brite dim switch and the headlights. One more thing comes to mind it may be the headlight switch itself, there is a built in circuit breaker that gives problems similar to this. Or the circuit breaker may be fine it just may be corroded connections in the system.
Didnt really help much did I At least you have some ideas on things to check out.
Sparky
Old May 15, 2002 | 10:14 PM
gray79f250's Avatar
gray79f250
HEADLIGHTS FLICKER!
poor ground or connection at headlight itself.Sometimes my truck does this to seams i wiggle the headlight connectors and its good for awile.
Old May 16, 2002 | 08:22 AM
fasch74's Avatar
fasch74
HEADLIGHTS FLICKER!
well i replaced the dimmer switch and it is still doing it. I jiggled every wire on that truck and also jiggled the headlight switch. i guess its time to replace the headlight switch eh?
Old May 16, 2002 | 09:12 PM
cyberbyrd's Avatar
cyberbyrd
HEADLIGHTS FLICKER!
Two things, first check the ground wire that goes from the battery to the radiator support. Second if that doesn't work then go for the headlight switch and when you pull that out if the plug on the wiring harness is dis colored or melted you can get a new end to put on the harness. If you don't replace the plug that is bad you will have problems in the future. (Been there done that)
Good luck
Old May 17, 2002 | 12:38 AM
adobbs's Avatar
adobbs
HEADLIGHTS FLICKER!
its the switch have had 4or 5 go bad on truck I have had. and had a shop for a while we replaced a lot of them they have a breaker built in the switch and it gets bad the switch heats up and the breaker kick then cools off a little and back on a gine.most of the time you can drive for 30 min or so then light go off for a fu sec and then back on .will findly go off and not come back till switch cools off compleaty still check your wiring too but this is a commom ploblem with all Fords cars and trucks
Old May 18, 2002 | 10:44 AM
Howdy's Avatar
Howdy
HEADLIGHTS FLICKER!
I've had the same thing happen, too. Headlight switch.
Old Aug 2, 2002 | 04:23 PM
jiml's Avatar
jiml
HEADLIGHTS FLICKER!
I've got the same problem in my '94 F150! I mentioned it to a friend who told me his Taurus did the same thing and there was a recall on it, but I have found no recall for the F's.
Go to the link below and find a '94 Taurus (same exact problem). Maybe this could be enough to get Ford to fix it?? Its really irritating.
http://www.nhtsa.dot.gov/cars/problems/recalls/Index.cfm
Old Aug 2, 2002 | 06:29 PM
Tedster9's Avatar
Tedster9
HEADLIGHTS FLICKER!
I read about old Ford's having something called "Flashing Lights Syndrome" sounds like you have a good case of it, heh. The part number for your year truck is: D3ZZ-11654A Should be about 20 bucks and any parts store should have it or be able to get it. I just got done replacing the one on my 64. Sure wish I would have known about the button release for the ****, (on top of the switch body itself) hee. Still a 5 minute job
Keep 'er between the ditches.
Old Aug 5, 2002 | 02:50 AM
mutant's Avatar
mutant
HEADLIGHTS FLICKER!
Definately the light switch. I've had the same problem on both my '80 and '87 E350s. Replacing the switch fixed the problem.
--Heaven will be inherited by every man who has Ford in his soul--
Old Aug 5, 2002 | 01:21 PM
karljay's Avatar
karljay
HEADLIGHTS FLICKER!
mustangpt
Apr 22, 2015 09:59 PM
rookiemistake
Jan 12, 2015 10:22 AM
dwil
Apr 21, 2014 12:16 AM
crsweet78
21
Aug 4, 2012 12:37 AM
AspenF150
240
May 22, 2012 06:36 PM
