1965 headlight problem
Old Jan 10, 2015 | 05:27 PM
mustangpt's Avatar
mustangpt
After installing new gauge pod, I have no headlights. Parking lights work, turn signals work and brake lights work. Only headlights don't work. Already replaced headlight switch, dimmer switch. As soon as headlights are turned on the high beam indicator light comes on but doesn't switch off when dimmer is pressed. And still no headlights. Any help would be appreciated.
Old Apr 22, 2015 | 07:19 PM
Mike1's Avatar
Mike1
Did you check voltage at headlights? If you have voltage then look for a bad ground. It's also possible your dimmer switch took a dump.
Old Apr 22, 2015 | 09:59 PM
mustangpt's Avatar
mustangpt
Thanks Mike1. After many hours of tracking wires, voltage and grounds, I finally came across a bad ground on the horn relay on radiator support. It's in the wiring diagram but took me quite a while to track it down. Problem solved. Thanks everyone for the replies, I really appreciate it.
jackzisakis
Mar 28, 2017 09:29 AM
cabloom300
Jan 10, 2014 04:26 AM
dalesimp21
2004 - 2008 F150
Sep 29, 2012 07:06 PM
SkipTLoo
Jun 14, 2011 11:11 PM
goldfever
1983 - 2012 Ranger & B-Series
Jan 31, 2005 05:58 AM
