1997 Ranger speedometer problems
Old Aug 2, 2008 | 05:03 AM
JimAllen's Avatar
JimAllen
The speedometer stops working for a while....then it will start working for 2 weeks...then it will stop again...any ideas...this thing is driving me crazy
Old Aug 2, 2008 | 11:47 AM
pawpaw's Avatar
pawpaw
If your also having other problems with say, the cruise control not setting, or randomly dropping out, or the ABS acting up, or it's trouble light coming on, or the auto tranny shifting acting out, maybe the rear ABS speed sensors output is corrupt, or maybe it's wiring, or electrical connector is damaged or loose, or corroded, so put it on your suspect list, as all those other things as well as the speed-o use it's output.
It's located atop the front rear center of the rear differential.
Inexpensive & easy to replace, maybe a 15 min job.
Some trouble shooting thoughts for pondering.
Let us know what you find.
Old Aug 2, 2008 | 02:24 PM
JimAllen's Avatar
JimAllen
base model
2.3 5 speed, no abs andf no cruise control
Old Aug 2, 2008 | 02:47 PM
pawpaw's Avatar
pawpaw
I believe a 97 base model should have RABS.
Still suspect the speed sensor, it's wiring, or electrical connector.
Could be a dash cluster circuit board problem I suppose, but the speed sensor is usually the culprit with speed-o problems.
Authenticraft
26
Feb 9, 2015 05:35 PM
50trucking
Sep 23, 2014 03:13 PM
hittman1422
Apr 3, 2009 05:34 PM
sigtauenus
Feb 15, 2007 02:22 PM
whalerron
Jul 29, 2005 10:46 PM
