Sudden Battery Failure With No Warning.
Old Aug 9, 2002 | 10:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
I just spent the last hour replacing a battery, my second this month, two different vehicles tho. Both a sudden complete failure with absolutely no warning signs. My 93 Ranger battery failed less than a month ago and the starter failed last week with no warning. My 91 Explorer failed to start this evening. Both vehicles were in the driveway at the time of battery failure:-) With the starter I was not quite so lucky, it failed in the High School parking lot. The battery failures were interesting, there was just enough power to run a dome light, but turning on the lights or engaging the starter solenoid killed the batteries completely. Putting a battery load tester on the batteries showed 12.5 or 13V but when a load was applied the voltage went to zero. I had one battery fail suddenly long ago but all the others have shown signs of diminishing capacity for a while b4 failure. Why did these two fail suddenly and both in the same manner?
Old Aug 18, 2002 | 08:12 PM
elwhoppo's Avatar
elwhoppo
Probably just a coincidental occurance, assuming no over head alien drive bys.
Batteries these days don't last, every 8 to 14 months, I have a cell go dead, with the same no advanced warning.
I just always buy a long term Sears Die-Hard and get credit for the unused term ofthe battery applied to the cost of a new one.
If I was doing an expense budget projection, I would automatically include a $36 to $40 expense every 8 to 14 months.
Thats how reliable the battery failures are.
Old Aug 18, 2002 | 10:24 PM
Mike W's Avatar
Mike W
I only had one total failure without any warning. It was an Optima, started fine. 5 min later, would not start. Even the radio would not work. Never saw anything like that before.
Old Aug 19, 2002 | 12:13 AM
Torque1st's Avatar
Torque1st
Posting Legend
These two batteries both went like your Optima. Both batteries would barely run the door buzzer. Even the dome light would kill the battery on the Explorer sometimes. I have been driving and running batteries for over 35 years. Neither battery was the same brand. Of course nowadays they could have been built on the same assy line. I bought the replacements at Oreiley's about 4 blocks away because it was close and open.
Almost all of my other batteries have lasted 4 years or more and I replaced them the first time they didn't give me a peppy starter spin, or slowed down on an extended start. They have all been various brands, but most were from Western Auto or Advance Auto parts. I have bought a few "rebuilt" or recycled batteries and they have all lasted just like the new ones. The two that failed were not the "rebuilt" type. I would have replaced them with the rebuilt units if the shop that sold them had been open.
Old Aug 19, 2002 | 06:11 PM
bosshoss's Avatar
bosshoss
Hey Eric. Batterys can do some strange things. Just wait till the first cold snap. I have seen batterys blow up when the key was turned. I just changed a battery that went bad, and killed the alternator.
Dave Powell
Old Aug 19, 2002 | 06:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
On the new stuff alternators will not even charge a dead or low battery. They will burn up from an overload... Give me old iron!
Old Aug 19, 2002 | 10:56 PM
Mike W's Avatar
Mike W
Hi Eric, I think you mentioned before about the new alternators not being able to handle a discharged battery. This is really strange. Have you seen this yourself? What is your opnion of the duty cycle of a typical alternator? I put four on a 8hp engine, almost ready to fire up.
Old Aug 19, 2002 | 11:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Several of the new style alternators I have used have had warnings about failure if installed with a dead or low battery. The warnings stated that the battery must be fully charged before the alternator is installed. I have not seen this mishap but a mechanic friend has.
Have you ever read any of the warning labels on parts before you installed them? Some of them are comical like DUH! Others are "educational"...:-)
I don't have any figures but I have used similar components and equipment for industrial continuous duty applications. You could figure about 1/4 to 1/3 of the rated output continuously from some of the new alternators and maybe 1/3 to 1/2 from old large frame alternators depending on the environment the alternator is operating in (temperature and air flow).
Old Aug 20, 2002 | 08:50 PM
Mike W's Avatar
Mike W
Thanks for the info Eric!
Old Aug 21, 2002 | 07:45 AM
74dually's Avatar
74dually
Rusty Axlerod
Feb 28, 2023 11:19 AM
harleymc
Nov 22, 2016 02:17 PM
bayou barataria
Jan 11, 2016 10:16 PM
lancer09
Jul 25, 2013 11:28 AM
Michael Littman
Electrical Systems/Wiring
Dec 10, 2005 04:49 PM
